Signal re-location kit choices
Old Mar 25, 2011 | 08:31 AM
rjheff's Avatar
rjheff
I went with these. http://www.denniskirk.com/jsp/produc...=&skuId=212839
Using these directions from this forum.
http://ae1m.com/relocate_directionals/install.htm
I like how they look better than those that clamp to the tubes.
Old Mar 25, 2011 | 10:45 AM
DeneFXDWG's Avatar
DeneFXDWG
Originally Posted by ghostrider69
I have a set of these on my bike. The fit and finish is great.
http://cgi.ebay.com/ebaymotors/49mm-...item20b78cfa97
Thanks for the link, I bookmarked it. Now as somebody else mentioned, are these billet and of good quality and how hard is it to re-route the original wiring from inside the bars?
Thanks again.
Old Mar 25, 2011 | 11:07 AM
iDodgimus's Avatar
iDodgimus
Dene - I'm about to put these on my FXDB and I think they're the cleanest looking mounts out there... the spacers do give a small gap of a couple of mm's at the trees which was a little disappointing at first glance but i dont think it'll be too noticable when the blinker is mounted, either that or maybe it could get machined down a touch.
oh, and check this thread as they may not be compatible with 08+ dynas due to the angle of the pinch bolt (it sounds like 08 and up angled the bolt instead of having it come out at 90 degrees)
How's the island these days? Maybe I'll look you up to compare blinkers when I take my bob on its inaugural ferry trip
Old Mar 25, 2011 | 02:59 PM
DeneFXDWG's Avatar
DeneFXDWG
Good point iDodgimus, the pinch bolts are on quite the angle, that mounting method definitely won't work, time to go billet clamps. Now how hard is it to re-route the wires?
Old Mar 25, 2011 | 03:17 PM
kirk180's Avatar
kirk180
Damn....I'm diggin' those Joker LED ones. Wish I had known about them before pulling the trigger. Pricey, but clean.
Old Mar 25, 2011 | 03:40 PM
JaronB's Avatar
JaronB
+ on making you own. I love mine on the forwards!! Here's a couple threads on it.
https://www.hdforums.com/forum/dyna-...rols-done.html
https://www.hdforums.com/forum/dyna-...with-pics.html
Old Mar 25, 2011 | 04:41 PM
8541hog's Avatar
8541hog
Here, mount these down on the forward controls....
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old Mar 25, 2011 | 05:48 PM
hddan502's Avatar
hddan502
Under the tree's.
Old Mar 25, 2011 | 06:04 PM
jbrown4217's Avatar
jbrown4217
You can use two of the mounts from the left handlebar. You just drill the hole a little bigger and mount them on the pinch bolt. Quick, cheap and easy and it looks good as it keeps them in close to the trees. If you search front turn signal relocation it has been wrote up several times. Here's a crappy cell phone pic, I can take more if needed.
Old Mar 25, 2011 | 08:44 PM
2014streetglide's Avatar
2014streetglide
Hey jbrown, any idea if the 2 left signal mount will work on an 09 lowrider? I seen where some of the guys say that the 08+ Pinch bolts are on an angle. I am away on business and can't check my bike out. Thanks for any info
