Hey jbrown, any idea if the 2 left signal mount will work on an 09 lowrider? I seen where some of the guys say that the 08+ Pinch bolts are on an angle. I am away on business and can't check my bike out. Thanks for any info
I don't know for a fact that it will work, but the mount is manuverable so you should be able to position them so that they are straight. You could try with the one that is on the bike before you buy another one.
Another question, does the tank have to come off to properly re-route the front wires? Where are the wires cut, in the middle somewhere or shortened at the signal lights themselves? I've looked at my Dyna manual on the laptop but still trying to envision where to start.
Thanks
I didn't cut my wires. I left them as is. I took whatever slack there was and pushed back into the black opening on side of frame below gas tank. Then zip tied them out of the way.
Thanks for the tip, did the tank come off to do all this?
Nope. Never touched the tank at all. I cut the clips under bars that hold the wires. Cut them (clips) close and left other wiring in them. I slipped the wire out and down to the lower trees.
