Just Ordered Progressive Drop in Lowering Kit
Old Apr 1, 2011 | 06:13 PM
  #41
lhgdale's Avatar
lhgdale
Ok, I'll check
Old Apr 2, 2011 | 06:04 AM
  #42
jmeiers's Avatar
jmeiers
Cut 1/8" at a time off the supporting tab on the kickstand till you get the lean angle you desire.
Old Apr 2, 2011 | 07:29 AM
  #43
dFREDb's Avatar
dFREDb
+1 A bike lift is a must unless you have some very good friends willing to hold it up. I did mine with the stand attached to the bike, but if you can avoid this, it will make life so much easier. I used a die grinder at first, but the metal is pretty tough. Finally used a cut off wheel (well, maybe two or three). It's cheaper than buying a new kickstand. The only thing negative about doing this is you have to hunt a little for the hole for the tab to lock into when you park it. Some have suggested heating the stand up with a torch and bending it, but I wouldn't recommend it.
Old Apr 2, 2011 | 07:30 AM
  #44
lhgdale's Avatar
lhgdale
I did some searching and grinding some off the support is what I'm gonna do. Do I need to take the jiffy stand off to do this? I want to make shure I cut the right piece and do this correctly!
Old Apr 2, 2011 | 07:46 AM
  #45
dFREDb's Avatar
dFREDb
See above. I did it on the bike, but will be much easier off. You will see the tab and the hole it locks into on the frame, kinda a lopsided half moon looking thing. I cut about 1/4 inch, but you don't need to cut quite that much. If you have a good compressor and grinder, just grind it down a little at a time til ya get it where you want it.
Old Apr 2, 2011 | 08:12 AM
  #46
lhgdale's Avatar
lhgdale
Thanks dfredb, I'm gonna do this as soon as I get off work this afternoon. It sounds pretty simple.
Old Apr 2, 2011 | 08:31 PM
  #47
lhgdale's Avatar
lhgdale
Just cut a few MM off the tab on the jiffy stand. This mod was super easy! The bike sits alot better. I ground a little off the piece on the frame that the jiffy stand rests on. I think I am going to grind a little more off this piece since I would be happy if my bike leaned a little further over. Thanks for all the help.
Old Apr 2, 2011 | 09:13 PM
  #48
dFREDb's Avatar
dFREDb
You are very welcome! I owe folks on this forum untold thanks for all the help I've received.
Old Apr 3, 2011 | 05:22 PM
  #49
JohnFlorida's Avatar
JohnFlorida
Realhog.com sells a kickstand angle plate for around $20 . lets you use your stock kickstand on a lowered bike. My parts are on order -drop in progressives , arlen ness adjustable slam kit and kick stand angle plate. Will be installing this week on my 97 heritage. Not for looks but out of neccesity
Old Apr 3, 2011 | 05:52 PM
  #50
lhgdale's Avatar
lhgdale
A few pics of the finished product!
