bottoming out
Old Oct 20, 2006 | 06:43 PM
dakotacrk's Avatar
dakotacrk
Default bottoming out
what does bottoming out mean? Is it the shock traveling its full range of movement? Or the frame components colliding, like the swingarm against the frame? Or both
Old Oct 20, 2006 | 06:59 PM
soup48's Avatar
soup48
Default RE: bottoming out
You are priddy close. This is the full extent of the shocks extention or compression, but hitting hard. Like hitting a hole in the road and the shocks compress hard to the end.
Old Oct 20, 2006 | 10:22 PM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
it's usally the shocks bottom out, but not the swing arm to the frame or frame to road
Old Oct 21, 2006 | 11:05 AM
mikec's Avatar
mikec
I thought it meant " I need another BEER".
Old Oct 21, 2006 | 11:37 AM
grunt's Avatar
grunt
Bottoming out is full compression, meaning the rest is no more dampening. And bottom a shock out hard enough repeatedly over it will get damaged over time.
Old Oct 25, 2006 | 03:44 AM
WildBill76's Avatar
WildBill76
How much do you weigh ? You might need to set your shocks to max and get heavier fork springs.
Old Oct 25, 2006 | 08:07 PM
DGlide04's Avatar
DGlide04
Bottoming out can also occur when shorter shocks are installed or the bike is overloaded. Slammed looks cool, but it's not always that comfortable.
wiktor
Jun 19, 2013 06:53 PM
rich0924
May 28, 2012 11:51 AM
CK Bobber
Jul 30, 2009 06:42 AM
ltlpig03
Motorcycles For Sale
Sep 29, 2008 08:09 PM
bastardmaker
Mar 7, 2007 04:01 PM
