neutral light switch
Old Oct 22, 2006 | 12:20 PM
texasjuan's Avatar
texasjuan
Default neutral light switch
Anyone else having problems with their neutral light not working correctly? I took the switch off and ohm'ed it out and its definitely bad.
Old Oct 22, 2006 | 12:34 PM
DougsDyna's Avatar
DougsDyna
Default RE: neutral light switch
What year is your bike??
That was part of the recall on the 06 Dynas. If the bike is still under warranty, take it to the dealer.
Old Oct 22, 2006 | 12:39 PM
thebestofindica's Avatar
thebestofindica
My friend's 07 had the same problem. He took it to the dealer and they replaced a sensor in a matter of minutes. Good to go.
Old Oct 23, 2006 | 08:51 PM
texasjuan's Avatar
texasjuan
Its an 06 streetbob. My dealer is about 60 miles away. Dont really like them workven on it. I wish they would just give me the switch so I could change it myself.
Old Oct 23, 2006 | 09:21 PM
DougsDyna's Avatar
DougsDyna
There were approximately 13,400 Dyna (all models) made with a defective neutral switch assembly (not just the switch).
If your Dyna waqs one of these you should have received a recall notice. The kits are available at the dealer. Have the dealer look up your VIN and they can tell if you fall under the recall.
They have to go into the trans to do the repair.
If not, maybe you just have a bad switch, etc.
I don't like taking my bike in for service, because it generally sucks, dealing with Harley service techs.
Better to check on this while the bike is still under warranty.
DougJ
Old Oct 24, 2006 | 12:41 AM
hep0950's Avatar
hep0950
You need to go to the dealer and get the tranny recall done. They order a kit by your VIN and once they hsve it it takes about a day to put it in. I just had it done on my FXDI35 and neutral is much more pronounced and I can get it from second now here I couldn't do that before the recall fix.
Old Oct 24, 2006 | 01:36 AM
MrD's Avatar
MrD
I gotta 06 and about 2500 miles the same was occuring. It turned out that the sensor switch was intermitently failing when the engine temp reach a certain level. It mostly happened after being in traffic for extended periods and when I finally got into a good wind...... It left. The dealer could never make it repeat but he took my word and replaced it. I now have 4800 and no signs of it happening since!! Hope this helps...
jjwin98
May 28, 2011 05:19 AM
grumpy56
Dec 27, 2010 07:29 PM
skydrifter
Jan 22, 2010 03:42 PM
oldhippie
Nov 4, 2009 08:24 PM
PoCoBob
Feb 14, 2007 05:32 PM
