Riser install - question
Old Apr 24, 2011 | 06:17 PM
evanstock's Avatar
evanstock
Default Riser install - question
I got 4 1/2 inch risers off ebay, brand is bikers choice, only came with the risers. Wondering if I am using the same bolts or need new ones?
Old Apr 24, 2011 | 06:19 PM
dyna-rider's Avatar
dyna-rider
When I put 4 1/2 inch risers on my fxdc I used the same bolts. You shouldn't have a problem.
Old Apr 24, 2011 | 06:21 PM
Rickl's Avatar
Rickl
I agree. Bought the HD 4 1/2" risers and the supplied bolts where the same length. A little blue loctite and the job was quick and easy.
Old Apr 24, 2011 | 06:27 PM
misfitJason's Avatar
misfitJason
this is a pretty dumb question. If the bolts thread in then use the same bolts. If they don't then get different ones that fit.
Old Apr 24, 2011 | 06:30 PM
evanstock's Avatar
evanstock
Ha, I got more if you want. I was thinking that since the risers are longer that may require longer bolts, for structural integrity. But I got everything off now and looks fine to me. Thanks .
Old Apr 24, 2011 | 09:10 PM
05dyna88's Avatar
05dyna88
There are no dumb questions; answers though, see above.
Old Apr 24, 2011 | 09:38 PM
confederate's Avatar
confederate
Most Wanted
The stock bolts should work just fine. Before you install, I highly recommend changing the stock bushings to urethane. You have to pull them out anyway and they cost about $30.00 and are a major improvement over the stockers.
Old Apr 24, 2011 | 11:27 PM
evanstock's Avatar
evanstock
What type of improvement? I got everything on , all is tight but I'm noticing the very slightest amount of play when turning.
Old Apr 25, 2011 | 12:04 AM
HemiOrange's Avatar
HemiOrange
The stock bushings may be okay for the 4.5" risers and drag bars. That play you noticed will be magnified with taller risers or apes.
As for the poly bushings, a set of $10 J&P bushings #5000021 will do the trick.
You can install new bushings easily. Just loosen both riser bolts and remove one, rotate bar and riser on one side to clear, replace bushings, rotate back into place, replace bolt, do other side the same way. Now tighten the bolts down, take your time, while straddling the bike sight down the bars to see if they align with the top tree, if not, tweak them until they do and continue tightening. Sometimes, on tall risers, you have to loosen the bar clamps in order to get things to align straight.
I've had risers that used course thread bolts and some that used fine thread bolts. As stated above, if they fit, then use them. All risers have about the same amount of thread engagement, so longer or shorter bolts are not needed when changing riser heights.
Clifford05
Nov 10, 2014 07:08 PM
Voony
Aug 4, 2011 04:28 PM
Xenomorph
Feb 1, 2010 07:32 AM
MNrider
May 2, 2009 08:09 PM
labfreak
Aug 20, 2007 06:56 AM
