exhaust install question
Old Apr 25, 2011 | 07:53 PM
smokinfromshootin's Avatar
smokinfromshootin
Default exhaust install question
installing some bassani firesweeps i got from the guys at dr. vtwin. i was looking through the manual and it says i have to remove the O2 sensors (front and under the seat)...is this necessary?
Old Apr 25, 2011 | 08:50 PM
dsiltman's Avatar
dsiltman
Yes if you are putting them in your new pipes, the rear one plugs in under the seat and the front one plugs in in that little plastic cover above the regulator (unbolt the regulator to get at it). You can unplug them and take the pipes off and then take them out.
Old Apr 26, 2011 | 12:05 AM
HemiOrange's Avatar
HemiOrange
Yup, that's what I did. Also, if you are installing something like a Power Commander, you can order it already programmed for the new pipes and leave the O2 sensors off, but still intact with your take-offs. The new pipes probably come with plugs where the sensors screw in.
ghoticov
Sep 10, 2012 06:47 PM
luvtoride
Mar 2, 2010 04:55 PM
softail09
Feb 8, 2010 11:17 PM
slick37
Dec 27, 2008 07:42 PM
blacked out
May 28, 2008 03:21 PM
