Change is a comin'!
Old Apr 30, 2011 | 10:56 PM
traveler's Avatar
traveler
Doing your own customizing is ALWAYS the best route.
Good job. Looks good.
~Joe
Old Apr 30, 2011 | 11:27 PM
cjlandry's Avatar
cjlandry
Since I have two sets of stock pipes, I'm thinking of scuffing a set up and shooting them with some VHT Flame Proof flat black. I've used it on hot rod headers before with good results.
Old May 1, 2011 | 06:52 AM
maduxfn31's Avatar
maduxfn31
I did the same thing on my heat shields on my exhaust, paint is holding up great but the clearcoat has not held up as well just off the motor it's been 2 years that it was done gonna redo in paint this summer
Old May 1, 2011 | 07:02 AM
Sevendcmc's Avatar
Sevendcmc
Looks great man. Nice change and you can't go wrong with that paint.
I went with doing 1/2 my exhaust with pc.
Old May 1, 2011 | 09:13 AM
oestek's Avatar
oestek
Thanks for the kind words, folks!
Originally Posted by iDodgimus
Looks wicked dude, similar to what I did with my St Bob! I'd be interested in seeing a close up of the sigs and if I may be so bold as to suggest losing the reflectors...
Here's a shot of the sig...
Have yet to attack the front of the bike. The sun glare off the top of the triple tree is brutal, so that needs to be darkened somehow. And I have to fix my mirrors. All I saw was my arms, so I flipped 'em under the bars, but then they hit the tank. So I Added a couple inches of length to them, but.. they still hit the tank. Now I think I can put them up top again 'cause they're longer, but I welded them up with the heads designed to be inverted.. so I gotta cut 'em again and rotate the heads to be above the bars again. Then maybe I'll get to the reflectors.
Old May 1, 2011 | 04:44 PM
oestek's Avatar
oestek
Fixed the mirrors.. cut 'em apart and we-welded the stems so that the mirror head mount points at a 90 degree to the base, and now I can finally see behind me!
Old May 1, 2011 | 07:10 PM
hddan502's Avatar
hddan502
Looks great bud. I agree with a pinstripe needed up front. Defiantly a big change in the looks.
Old May 4, 2011 | 05:51 PM
rdl's Avatar
rdl
Default tank prep
Did the HD tank badges come off without too much resistance or did you have to destroy them in order to remove them?
Old May 4, 2011 | 10:52 PM
oestek's Avatar
oestek
They came off OK with some help from a heat gun, and I removed the sticky gum from the tank with some 3M
General Purpose adhesive remover.
fenwick
Sep 25, 2025 06:08 PM
FLSTFI Dave
Screamin Eagle CVO Models
13
Jun 26, 2019 10:34 AM
jphillips63
2014-2024 Touring Models
15
Jun 12, 2014 10:56 PM
Mr.Guns
Jun 30, 2012 05:57 PM
JRK5892
Mar 24, 2010 02:44 PM
