handle bar grips
Old Oct 25, 2006 | 06:39 PM
BLT's Avatar
BLT
Default handle bar grips
hi i got 2006 street bob i got new handle bar grips is this something i can change my self not to worred about left side its right side
Old Oct 25, 2006 | 07:42 PM
HOGRIDA_06's Avatar
HOGRIDA_06
Default RE: handle bar grips
It's pretty easy, it was a one beer job for me. Ok maybe two beers. Follow the instructions that came with the grips and you should be fine. Be carefull not to drop the little brass furells thay can be hard to find.
Old Oct 25, 2006 | 08:07 PM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
Not bad, the service manual explains it. Be careful the lil brass furels don't fly away on ya.
Old Oct 25, 2006 | 08:27 PM
drhooligan's Avatar
drhooligan
A good trick that makes the right grip change a snap. Loosen the adjustment all the way on both throtle cables giving yourself as much slack as you can. A pair of needle nose pliers can be helpfull also when you detatch the brass ferrels and cable from the stock grips and connect to your new ones. You may want to mark the adjustment or nut position on the adjusters before you loosen them so they can be easily retightened to their original position.
You can do it!
Old Oct 25, 2006 | 09:17 PM
3dynaP's Avatar
3dynaP
Easy deal, just take your time.
Old Oct 25, 2006 | 09:29 PM
GeorgeJ's Avatar
GeorgeJ
Just did it on my 01. Like the rest of the posts said careful with the brass ferules. They are tiny and dissappear (hopeful not in the control). Another tip I heard of (after I did them) was to loosen the bar clamps and you can slide the handle bar in and just pull the assembly right off the bar after you loosen it. Sounds like it would be easier than playing with the carb side cables. Oh yeah another tip, count the threads on the adjusters on the throttle cables (idle and throttle). THis way when you back'em off you can put them right back where they were. Good time to lube cables as well. All in all it was 30min thing.
George
Old Oct 25, 2006 | 09:33 PM
GeorgeJ's Avatar
GeorgeJ
This is what I used for instructions. https://www.hdforums.com/m_69241/tm.htm
George
Old Oct 26, 2006 | 03:59 PM
BLT's Avatar
BLT
thanks for all the feed back i am going to give it a try on the weekend
Old Oct 26, 2006 | 06:07 PM
Whiffleboy's Avatar
Whiffleboy
Be gentle when installing the cable/ferrules in your new grip slot. You don't want to crimp or crease you cable wire. A dab of grease can help keep the ferrule in place while you're trying to slip it in it's new home.
Whiff
Old Oct 26, 2006 | 07:26 PM
DougsDyna's Avatar
DougsDyna
Follow the advise given........... The brass ferule is EXTREMELY hard to find. I lost one of mine on a black top surface, and it took me a week to find it.
DougJ
