Threw a code
Old May 9, 2011 | 09:16 PM
coachchris's Avatar
coachchris
Default Threw a code
I threw the code for the rear o2 sensor stuck open or not responding, I think it was po154. Does this simply mean the sensor has gone bad or is it possible the wiring went out? Is there a way to check for one or the other?
thanks
Old May 9, 2011 | 11:42 PM
Swede405's Avatar
Swede405
Try swapping the sensors front to back. They just unbolt from the pipes and unplug from the wire harness. That will tell you if the problem exists in the sensor or elsewhere.
fhartell14
May 31, 2019 04:02 PM
robsfirsthd
Feb 24, 2016 08:13 AM
deezy139
Aug 19, 2014 10:05 AM
FXDWG12
Jun 7, 2013 06:59 AM
coachchris
Jun 4, 2011 07:15 PM
