dyna floorboards
Pic's to come when I get the brake lever and pad next week.
Beat wishes.... Tim
Beat wishes.... Tim
Next to that I'm sure a lot of members over here are interested to see a list of parts and p/n's you used for this mod...
I you are 5'8" ish or shorter, you might want to concider the FXDP board kit. Although I've not seen them in person, there are many helpful threads on this site that helped me to decide on the FLD boards, just "Search" FLD Switchback on this sight or "Google" Wyatts footboards (And they are out there) to get more than enough info to help you in that decision.
The FLD rear brackets go forward then up, The FXDP rear brackets go straight up, making them about 2 inches further to the rear than the FLD's. Also, the FLD's are slightly lower (about an inch) in the rear where-as the FXDP's are more level.
one of the best threads on these comparisons was posted by FXD2003Rider dated 08-20-2011. His photo's pritty much convinced me to go to my parts guy and, "pull the trigger" (buy) on the FLD's. I'm 6'1" on a good day.
Other things to concider, IF you have HD forward controls now, The FLD forward brackets position your shifter and brake levers a little lower and to the rear. So, they'll feel a little funny. as does the whole set-up at first to me. Although you can make the HD Fwd control brake lever work if you modify the lever, I don't suggest it. It's in the way and, looks like Sh@t.
https://www.hdforums.com/forum/dyna-...na-photos.html
... parts list ....
I't's taken about a month to get in all the parts but, I think the wait was well worth it. These are for the '12 FLD footboards and, the people I hang with say " They look like they've belonged there the time."
Here 's a list of P.N.'s and prices as they applied to me, having an'06 Superglide W/Fwd controls and Vance & Hines Bigshot exhaust.
For the footboards:
54165-12 SUPPORT, right footboard $ 52.72
54172-12 SUPPORT ASSY, right footboard $ 68.75
54173-12 SUPPORT, left footboard $ 52.72
54174-12 SUPPORT ASSY, left footboard $ 68.75
50621-06 FOOTBOARD ASSY w/pads $ UNK (See note #3)
50614-06 PAD, footrest $ UNK (See note #3)
7354 LOCKNUT (4) $ UNK
50674-05 BOLT, shoulder $ UNK
4512A SCREW $ UNK
For the brake:
38157-12 BRAKELEVER ASSY $ 111.00
42416-06 PAD, brake pedal $ 4.25
4997 SCREW $ 4.00
38160-12 CAP, brakelever $ 10.95
38161-12 PUSH ROD $ 72.56
42665-03 PIVOT SHAFT $ UNK. (See note #1)
For the shifter:
33789-12 SHIFT LEVER $ UNK. (See note #2)
34887-06 SHIFT ROD $ UNK. (See note #2)
6702 WASHER $ UNK (See note #2)
7736 ACORN NUT $ UNK. (See note #2)
If you have mid-controls:
2882W BOLT $ UNK (See note #4)
7710W NUT $ UNK (See note #4)
34639-93 RETAINER $ UNK (See note #4) For 96-00 models
34639-01 RETAINER $ UNK (See note #4) For 01 and later
34640-93 COVER, Shift shaft $ UNK (See note #4)
3231B SETSCREW $ UNK (See note #4
NOTES:
#1; If HD Fwd controls are already on the bike, the existing part is the same P.N
.If NOT HD Fwd controls, OR is HD mid controls, this part may be needed.
#2; These parts are needed if the bike has mid controls. If HD Fwd controls are already on the bike, these parts are not needed.
#3; These are Stock FLD (Chrome) footboards and come with the PAD, I Opted for P.N. 51322-08 FOOTBOARDS (Black) from the 12 HD custom book (Im not real big on chrome) and my parts guy gave me a set of stock take off standard PAD, footrest.`
#4; These are parts listed as an option to removing the outer and inner primary cases to remove the existing shift lever shaft and, cap the holes.
Sorry, no pics yet, soon to come. Best wishes Tim
