Shock angle = Length question?
Old May 15, 2011 | 08:00 AM
Bobber Jake's Avatar
Bobber Jake
Default Shock angle = Length question?
I just bought a 07 FXD and it cam with 10 1/2" shocks on it and I want to raise the rear end about a inch so the ol lady can ride. But with the angle of the shocks, a inch longer shocks can't add a in height can they. So I am just trying to figure out the length of shocks I will need.
Old May 15, 2011 | 08:07 AM
stilup's Avatar
stilup
When I purchased my rear shocks from Works they are 5/8" longer and the engineer said that with the angle the raised height would be 3/4".
I'm no engineer but the bike did raise up higher than 5/8"
Old May 15, 2011 | 10:53 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Default shock length
To answer your question, remember Trig?
When you purchase a premium shock, they have a thing called rebound. Rebound can be initially look like the depressions in the road. 1/2 of the bumps in the world have rebound parts. Level road than hit a depression your bike or your wheel must go down. HD have no or very little rebound which means you and your bike falls down into a depression.
Rebound is set by spring pre-load which sets your piston inside of the shock body with room to move down. Ohlins & Penske are set for street 1/3rd of the stroke inside of the shock body. This happens when you get onto the bike with the weight that you set your sag at.
In examining a speed bump your wheel moves up the lead side and your shock compresses. Hit the crown than traverse down the lee side and the shock will extend up to the whole extended length (depending on the size of the bump) than return to the pre-set riders sag.
This means that a premium 13" shock is not a 13" shock when you sit on/operate the bike. It is up to you what length you wish your bike and what method and ride quality is for your own preferences and needs. I hope I answered your question.
Old May 15, 2011 | 02:00 PM
bikerlaw's Avatar
bikerlaw
I am just looking at your sig picture. I see full cover chrome shocks. I don't believe there are any 10.5 full covered shocks. Are you sure they aren't 11 inch Progressive 412's? Did you jack the wheel off the ground and measure them fully extended? If so, for a tad over 200 bucks you could buy some new 12" inch shocks and sell yours for close to half that on ebay. You'd be all set up for around 100 dollars.
Old May 15, 2011 | 07:48 PM
orange-n-black's Avatar
orange-n-black
[a] squared + [b] squared = [c] squared
Old May 16, 2011 | 09:31 AM
dreamer65's Avatar
dreamer65
trigger the horse oh yea sure
13glidestreet
Nov 11, 2017 09:22 AM
justin_ryan
Jun 8, 2015 04:59 PM
justin_ryan
Jun 7, 2015 09:45 PM
sbeamer
2014-2024 Touring Models
Jan 19, 2015 07:02 PM
Chicago Spike
Sep 2, 2008 06:38 PM
