changing outer primary
Old May 18, 2011 | 07:45 PM
fighthedude's Avatar
fighthedude
Default changing outer primary
As the title says I am changing my outer primary. In the manual it does not say anything about putting thread locker or anti seize on the bolts, however when I removed the bolts it looked like there was anti-seize. (cream colored on the threads) For those that have removed the primary or put some on, Are you putting any substance on the bolts? I have both loc tite and anti seize to use if necessary. Also the same substance was on primary drain plug. Thanks
Old May 18, 2011 | 08:44 PM
apehanger65's Avatar
apehanger65
I would put some loc-tite on them
Old May 18, 2011 | 09:14 PM
fenderzig's Avatar
fenderzig
Locktite thread sealer 242. Permatex makes some as well. It is blue, medium strength and should be used in accordance with the torque values and torque sequence as per the manual. This is important to follow so that you don't mess up the new primary gasket with imbalanced or over-zealous tightening...that is assuming you're replacing the primary gasket which I would also recommend. Good luck!
lkr0
Apr 30, 2014 10:55 AM
Crazy
May 25, 2011 07:28 PM
hfdarson1
May 10, 2010 08:04 AM
HOGRIDA_06
Jan 4, 2010 09:42 AM
jamesguynn
Sep 1, 2005 06:12 PM
