shifter shaft seal
Old May 20, 2011 | 08:10 PM
bugzapper's Avatar
bugzapper
Default shifter shaft seal
2004 wide glide with a fluid leak around the shifter shaft. Would it be transmission or primary fluid. I have HD Syn 3 in all 3 holes so there isn't a noticeable color difference. I would have to ride it to repair shop, any problem with that if I check levels?
Old May 20, 2011 | 08:32 PM
Spanners39's Avatar
Spanners39
If you mean the one behind the inner primary, where the link arm sticks up and attaches to the rod to your forward controls then it is tranny fluid. If using mid controls there is one from the outside of the primary which would be primary fluid.
Why are you using H-D syn3 in the tranny? it needs to be a Hypoid transmission oil. I use Spectro gear guard.
It is fine to ride if you check the levels.
Northern Cowboy
Jun 14, 2015 04:17 PM
bobbyjoes
Dec 28, 2012 07:12 PM
mke125125
Feb 21, 2012 10:36 AM
bugzapper
May 20, 2011 08:08 PM
splitting_lanes
May 27, 2008 08:52 AM
