progressive 412's
Old May 21, 2011 | 12:13 AM
Crushrus's Avatar
Crushrus
Default progressive 412's
is the only difference between the 'dyna' version and the sportster version the spring rate (heavy duty vs. standard)? from looking at pics, that seems to be the case, but wasnt sure.
ordering a set off ebay, cant decide which to go with. i'm only 180, never a passenger, so i'd think standard would be fine, but not sure if the extra weight of the bike makes heavy duty better.
anyone?
Old May 21, 2011 | 05:23 AM
Spanners39's Avatar
Spanners39
Progressives tend to be on the stiff side so go with standard.
Old May 21, 2011 | 06:19 AM
fenderzig's Avatar
fenderzig
I'm about 190 and I hve the standards. They are fine.
Old May 21, 2011 | 07:11 AM
bikerlaw's Avatar
bikerlaw
anyone?
No, they are not the same shock. In addition to the spring rates, the internal valving is different from Sportsters to Dyna's. The Dyna line uses extremely stiff internal valving and springs compared to the XL's. Running Sporty shocks on a Dyna would be like having marshmallows for suspension. Secondly, since your 180 lbs, the standard duty shocks would be the best choice. I believe the heavy duty's are for riders 225 and heavier. I had the exact same question myself. I found a killer deal on Sporty 440's and called Progressive to ask if I could just swap the right Springs and put them on my Dyna. What I just mentioned is what they told me.
Old May 21, 2011 | 08:15 AM
Crushrus's Avatar
Crushrus
cool, thanks a lot.
jets2fix
May 3, 2015 11:17 AM
hardtaco
Aug 23, 2014 03:13 PM
Falcon81
Apr 6, 2014 12:41 PM
jus2anoyu
Aug 12, 2013 03:50 AM
ralix13
Dyna Parts
11
Sep 18, 2011 08:52 AM
