where can i buy cables and wires from besides dealer?
I just helped a guy put 14" carlinis on his Fat Bob, we went with 14" over stock, but they could have easily been 12" over stock. How you route them can make a little difference.
Magnum Shielding makes this very easy, just look up your bike and select length based on stock.
1 front brake, it will come as a kit with all 3 cables you need, just read the description carefully, make sure you order it that way.
2 throttle cables, idle and throttle
1 clutch cable
You will need crush washers for the brake lines, as I recall they come with the brake cables.
You will need brake fluid, it will say on the cover what type to use.
