Tranny dipstick broke
Old Jun 12, 2011 | 10:14 AM
2004&2002 Wideglide's Avatar
2004&2002 Wideglide
1st Gear
Default Tranny dipstick broke
Hey fellas. Well, yesterday I dropped all my fluids and everything was going fine, until I pulled my tranny dipstick and saw that it was no longer there. The threaded plug that it was attached to is now a just, and the dip stick portion is floating around somewhere in the transmission. I last dropped all the fluids about 1500 miles ago before I put it up for the winter and the dipstick was attached then. So somwhere between last night at 8:30 and 1500 miles ago, it broke. The bike currently runs great, shifts fine, the clutch works great, no problems mechanically as of yet.
What should I do? Should I take it to a dealer and let them dismantle the transmission in hopes of finding it? Or is the dipstick made of plastic and are the gears capable of chewing up without causing the rear wheel to lock and throw me for a loop {been there, not fun, don't wanna go back}.
Any help on this would be much appreciated guys! Thanks
Old Jun 12, 2011 | 10:52 AM
reded's Avatar
reded
I'd probably take the cover off of the top of the tranny and inspect the situation. It's most likely either chewed up or stuck in a spot where its done no harm.
Old Jun 12, 2011 | 01:08 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Pull the side cover off, if it's not in there then it probably migrated to the bottom of your trans. Might be able to pull the side door off and see it in the trans. but I have a feeling it's in the side cover.
Old Jun 12, 2011 | 01:20 PM
Ole T Sport's Avatar
Ole T Sport
Here's an old broke dipstick thread, might help, you're not alone.
https://www.hdforums.com/forum/prima...ipstick-2.html
Old Jun 12, 2011 | 04:18 PM
dyna rider's Avatar
dyna rider
Default Dipstick
Why not take a magnet and go fishing for it ? If you can't find it or get it out, you can then take the cover off and the side door..
Mine is made of a hardened metal and isn't likely to be chewed up. Engine oil maybe but not the trans dipstick.
Old Jun 12, 2011 | 05:11 PM
2004&2002 Wideglide
1st Gear
Thanks for the help guys. I will start rippin it apart in an hour or so and let you know how I make out.
edaddy
Shovelhead
Apr 3, 2019 10:16 PM
edaddy
Panhead
Mar 27, 2019 08:41 PM
ddunham
Jul 24, 2018 07:02 PM
jp13
26
Oct 3, 2017 10:41 PM
Then Came Bronson
EVO
24
Sep 16, 2016 03:56 PM
