fluid leak
Old Jun 14, 2011 | 08:54 AM
biker sean's Avatar
biker sean
Default fluid leak
i have a 02 wideglide and have a leak behind the primary. it is tran fluid. it does not leak much just enough to bother me. one guy told me it was too full and it was coming out of the overflow. changed fluid a couple of times since it started leaking. i dont think it too full always put in what is what the book say. always used bel-ray. any ideas?
Old Jun 14, 2011 | 09:11 AM
six_strng_slnger's Avatar
six_strng_slnger
I have an 01 and my shift shaft seal is leaking, right behind primary.
Old Jun 14, 2011 | 09:45 AM
HOGRIDA_06's Avatar
HOGRIDA_06
Probably won't be able to tell whats leaking until you rip into it. When mine started leaking trans fluid from that location it was because my main drive bearing was shot.
Old Jun 14, 2011 | 06:46 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
My shift shaft seal leaked after only 7k miles and the replacement seal was an upgrade from the original 02 seal. When I change my trans oil I only put in 22 ozs. Service manual calls out 20-24 ozs.
Old Jun 16, 2011 | 08:58 AM
biker sean's Avatar
biker sean
Thanks to all!
1999dynasport
Mar 16, 2014 11:42 PM
6speed51
Mar 2, 2012 07:00 AM
djw
Apr 20, 2009 01:52 PM
Toms_softail
Sep 26, 2007 06:12 PM
wactc88
Sep 8, 2006 10:25 AM
