I know this subject has been beat to death but I have a question for any Harley mechanics
I am very mechanically inclined on cars ( can build engines from scratch) and such but have not much experience on Harley V twins. I have yet to dive into mine.
My question, if I buy the hydraulic cam tensioner upgrade kit ( oil pump, chain sprockets etc) do I need any special tools to do the upgrade?
I have the Harley service manual for my bike and all the regular tools anyone would want
Has anyone performed this upgrade themselves that could share their experience?
Just trying to save a buck and know it was done right......and learn at the same time
Thanks
TC88 right? You need cam tensioner unloader, oil pump alignment screws and a puller for the inner cam bearings, you can get them all at the following link. I'd throw some performance cams while you are there. http://georges-garage.com/tc_engine_1.htm
Here is another thread I posted a while ago, it is my Fatboy, I didn't upgrade to a new style oil pump / auto tension unit though. Hope it helps! https://www.hdforums.com/forum/softa...installed.html
Thanks
looks like my Indy may be about the same price after I buy the tools, Not sure but I will check with them. Maybe a side job by one of the mechanics that has worked on my bike before.
I wouldn't mind buying the tools if it wasn't just a one time use. Even my friends that ride don't work on theirs so they wouldn't even borrow them *grin*
To be honest, the only tool I bought is the oil pump alignment screws, they are cheap. You can borrow bearing puller from Napa or Autozone I heard, the spring tensioner I just use water pump pliers to unload, make sure you order the B-148 inner bearings. Special tools are good but you can make it work without buying all of them.
Yeah I knew about getting past the unloader but I thought the bearing puller might have been Harley specific but it sounds like it is not
The alignment screws are no problem, I have heard about a newer style of bearings and I am guessing they are the ones you mention above.
Are the bearings a dealer item only?
I just did mine. If you are careful and creative you can unload the tensioners with out special tools. Rent a blind hole puller from autozone for free, and use old cam to tap in new bearings. And the oil pump alignment can be done be rotating the rear tire in 5th gear while tightening the oil pump bolt slowly. I used basic hand tools to do the swap and it wasn't to bad.
Don't buy inner bearings from dealer, they have problem. Get the Torrington B-148 full roller bearings at George garage, those are the problem solving ones. Yes, the harley puller is nice but you can use other pullers instead, the bearings are easy to pull out.
You don't need bearing installer, find a deep socket same as the bearing OD, use an extension and hammer, drive it in. Another thing, are you planning to remove the rocker covers? You can save some time by cutting the old pushrods and install a set of adjustable pushrods, that's up to you.
