Street bob Ignition switch relocation help!!!!
Old Jun 16, 2011 | 01:32 PM
buben2000's Avatar
buben2000
Stage I
Default Street bob Ignition switch relocation help!!!!
For all of those who have done this mod, I need your help!!!!
Im trying to relocate my ignition switch in my 07 street bob from the neck to the dash. No problem getting the dash out and the rubber grommet on the neck as well as the plastic cover under the frame to access the wiring on the existing switch.
However.................. how in the world do you get to the plug to disconect it from the switch?
My paws are too big for that and even though I've loosen up the switch from the frame it by turning the keeper ring it will not completely come out so I still cant get to the plug ears so I can disconect it.
Any tips? ideas?
Thanks in advance!
Old Jun 16, 2011 | 08:14 PM
dynabobster's Avatar
dynabobster
I actually used a pick through the small hole in the frame where the down tubes meet and unclipped top side of the connector while pulling on the connector and then was able to grasp the connector and push the bottom clip with my thumb and remove it.
It should come down and out with the retaining ring removed though?
Old Jun 16, 2011 | 09:22 PM
bberck's Avatar
bberck
It took a long skinny screwdriver and some cussing but finally got it unhooked.
djack
Aug 15, 2022 10:25 AM
walterwindbag
Mar 8, 2019 09:04 PM
Schwanz583
Jan 1, 2013 07:43 PM
airjoe
Feb 8, 2011 01:23 AM
street2007bob
Jun 12, 2009 07:27 PM
