07 Lowrider 1.75 Baffle, FuelMoto PC III and Air cleaner kit. Bike runs and sounds nice. Under $650. They my sound a little quite at first, but they breakin nice.
2010 FXDC stock. Added Rush Slash cut 1.75 slip on's and have decel pop with and without XIED's hooked up. Rush said I might have one of those "extra lean" bikes and I should spend $70 to see if the 1.5 baffles take it out. Nightrider say's add some air, and if that doesn't take it out, get a tuner. Guess I'll get a AC, and if that doesn't do it, probably put a Dobeck unit on there. Hopefully I'll get lucky and the air does it. Just had to replace a washer, and now I need a new mower. Harley parts have to wait. I think it's a crap shoot if you get popping or not, but I've learned to control it some with the throttle.
Instead of just buying an air filter just take the cover off and ride with it that way. I am assuming you have a stock air box and filter. If you remove the cover exposing the air filter it will get alot more air even though its a stock filter. This should give you an idea before spending more money on something not needed. I was always told that if you get decel poping your running to lean. If you install a performance filter you will be running even leaner. So if you want to try adding more air then just take the stock cover off and run it that way.
I have v&h big shots, stage 1 ac, and tuner. I still get decel poping. I was told by dealer that did the tune decel poping wont hurt the motor. ?
Have 2011SGC and have V&H slip ons and no tune and have slight popping at times but runs better and all the rest of bike stock. Will just ride and not worry about popping because it is not hurting the motor. Had sam popping with stock but hard to hear due to muffler and cats covered it up.
