Ricor shocks arrived, now how do I install them?
Old Jun 19, 2011 | 03:15 PM
FXDF_Lover's Avatar
FXDF_Lover
Default Ricor shocks arrived, now how do I install them?
My fat bob has 12 inch shocks and I ordered some 12.5 incher Ricors.
First off, they are a thing of beauty. Look real nice, precision piece of work!
Okay, regarding install, is a bike lift a must? Can I install them on the bike without the stand?
Old Jun 19, 2011 | 05:07 PM
motolocopat's Avatar
motolocopat
I'd say that you should be able to just unbolt one at a time and bolt up the new Ricor. Might need a buddy to lift up rear a bit or go and get a basic bike stand.
Nothing for the forks?
Interested in hearing how you like the Ricor's as I'm considering them, and doing the 12.5" as well to try and get a bit more travel and rear end up should make handling a bit quicker
Old Jun 19, 2011 | 06:12 PM
hell hound's Avatar
hell hound
you will need to get the back tire off the ground to install longer shocks, so yes i would get or borrow a jack
Old Jun 19, 2011 | 07:09 PM
stilup's Avatar
stilup
My (Works) streettracker shocks are 12.6 and actually raised the bike 3/4".
They are nitrogen charged and mount upside down.
I use the stock jiffy stand and use a 1/2" board under my stand to check my oil levels.
The bike leans more and that is a good thing as a person backed into it a couple weeks ago and didn't do much but bend the license plate and loosen the muffler. the extra lean kept the bike from falling over. I just let her go.
The bike corners very well with the extra height.
Changing the shocks is a breeze, be sure to torque to spec and use the blue loctite.
Old Jun 19, 2011 | 07:35 PM
SouthpawHD's Avatar
SouthpawHD
You could use any regular far/floor jack to raise up the frame to allow the rear section to drop down. Just have a buddy straddle the bike to hold it upright.
Old Jun 19, 2011 | 07:42 PM
stilup's Avatar
stilup
If your going to maintain your bike get a real lift. they are reasonable.
Old Jun 20, 2011 | 12:46 AM
HemiOrange's Avatar
HemiOrange
Heck, if a bike lift is too far out of the budget, just get a sturdy piece of 2x8 lumber about 2-1/2 ft long, drill an appropriate sized hole in one end of it to stick about a 2-1/2 ft piece of 1" to 1,5" pipe through. Now just place the 2x under the rear of the frame and step down on the pipe "arm". That will raise your bike up about 7.5 inches. If you need to raise it more, just put some 1" thick flat boards under the "lift" and try again.
That would closely approximate some of the MX lifts than I've made in past out of tube steel, I also made a shorter one for a Harley years ago that I still occasionally use on my Dyna.
A hydraulic lift would be handier, since you can more easily raise and lower the back to align the shock holes, but at the time I did mine I just used my old step on lift. Do one shock at a time, and if needed, just use a lever (crow bar, claw hammer, whatever) under the tire to raise/lower the swingarm to align the holes.
Skully
2014-2024 Touring Models
17
Apr 29, 2014 10:54 PM
wichitaks
Apr 25, 2014 08:40 AM
jacknthebox
Apr 23, 2012 11:59 AM
Fupl18
Feb 8, 2009 07:35 PM
cHarley
Mar 12, 2007 05:21 PM
