do i need a torque wrench?
Old Jun 23, 2011 | 08:24 AM
twistr's Avatar
twistr
If your going to wrench on your on bike, even a little, it's a good tool to have in the toolbox...you can find good ones at very reasonable prices.
Old Jun 23, 2011 | 08:33 AM
Cazimere's Avatar
Cazimere
Check out Harbor Freight. I got 3, 1/4" 3/8" & 1/2" for around 60 or 70 bucks.
Old Jun 23, 2011 | 08:51 AM
USMAMule's Avatar
USMAMule
For the Derby cover? If you're a gorilla you need one. If not and you are just average strong probably not - just tighten in a star pattern until its a "bit too difficult to tighten further."
Then again - feel is subjective and everyone's "feel" is different which is where a torque wrench comes in. It takes the guess work out.
In general I think you should have at least a 3/4 if you are going to do anything more than oil changes. For the money (you don't nee the Snap on tools version for you home garage), piece of mind can't be beat.
USMAMule
Old Jun 23, 2011 | 09:11 AM
Grundlepunch's Avatar
Grundlepunch
Originally Posted by USMAMule
For the Derby cover? If you're a gorilla you need one. If not and you are just average strong probably not - just tighten in a star pattern until its a "bit difficult too tighten further."
USMAMule
agreed. I find that using a torque wrench on small fasteners usually makes people snap them hahah
Old Jun 23, 2011 | 09:25 AM
DoubleZ's Avatar
DoubleZ
alright thanks guys. im not worried about snapping the bolts i know enough to know what tight is. my main concern was if it would leak if all the bolts weren't all at exactly even specs. so looks like ill be tackling this job without one.
Old Jun 23, 2011 | 09:45 AM
MXerwithaBob's Avatar
MXerwithaBob
As a mechanic, I don't torque everything that I should, I've developed a pretty good "feel" over the years. If you are unsure, then you should probably use a torque wrench. IMO you get what you pay for with torque wrenches, I feel the cheap ones are complete garbage. I use the digital ones at work and I bought one to use at home on the bike. They are extremely accurate and they will do in-lbs, ft-lbs, nm, it's like multiple torque wrenches in one. I guess I don't understand why someone would want to work on a 15-20K bike with a $60 torque wrench. The derby cover is not that big of a deal but if you are going to be removing wheels or doing engine work, I would not trust the cheapies. Again, JMO.
Old Jun 23, 2011 | 09:49 AM
CHOPPIN' CHARLIE's Avatar
CHOPPIN' CHARLIE
Cool Torque wrench
YES. TWO WOULD BE GOOD. " & #. CHECK H-D SHOP MANUAL AND NOTICE 99% OF FASTENERS HAVE TORQUE VALUES. DERBY COVER EVEN TELLS PATTERN THEY WANT FASTENERS TIGHTENED.
Old Jun 23, 2011 | 11:50 AM
lo-rider's Avatar
lo-rider
...I think you should have at least a 3/4 if you are going to do anything more than oil changes...
Sorry, but a 3/8"-drive (inch-pounds) and 1/2"-drive (foot-pounds) are all that's needed.
Old Jun 23, 2011 | 11:59 AM
Tony P's Avatar
Tony P
Originally Posted by DoubleZ
so i bought a new derby cover and i need to know if i need a torque wrench to install it. i know that there is a torque spec for the bolts but is it actually necessary or is the old good and tight method fine?
No. I replaced my derby cover over 2 years ago using a standard tool. No leaks. Ever.
Old Jun 23, 2011 | 12:12 PM
EricInNCa's Avatar
EricInNCa
My feeling is that if you've done much wrenching you will definitely develop a feel for "pretty close" torque. The size of the wrench and the size of the fastener all need to come into play when your doing your general stuff and the feel you get when tightening them. That being said, I have two Craftsman torque wrenches. One for in/lbs and the other for ft/lbs. Using them really gives you a peace of mind knowing you've done it right. Sometimes your "feel" is close and other times it's not. Bottom line is that you should get the wrenches and do your bike right. You depend on your bike to be a safe and reliable means of transportation and as the saying goes....Safety is no accident!
