do i need a torque wrench?
Old Jun 23, 2011 | 01:22 PM
skinless's Avatar
skinless
There are torque specs and the invention of touque wrenches for a reason
Old Jun 23, 2011 | 01:32 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
Agreed. I use 'em.
Old Jun 23, 2011 | 01:36 PM
RayBoy's Avatar
RayBoy
If you're new to torque wrenches do yourself a favor and PRACTICE using your new wrench first so you get the feel for the 'click' or break when the set torque is reached. Just drop a bolt in a vice, set your wrench to a few inch pounds (or foot pounds), and torque on the bolt head until your wrench reacts. Better to practice on an old bolt than on a new derby cover screw.
Old Jun 23, 2011 | 01:43 PM
JCleary's Avatar
JCleary
Sometimes torque specs can be deceiving too... I have had situations where I feel the bolt starting to "yield" before the wrench clicked. Experience an d practice helps...
Old Jun 23, 2011 | 02:18 PM
Sharknose's Avatar
Sharknose
If you can tighten it down far enough that it doesn't leak, while not tightening it enough to strip the heads...no.
Old Jun 23, 2011 | 02:46 PM
DoubleZ's Avatar
DoubleZ
do the derby cover bolts need loctite?
Old Jun 23, 2011 | 02:56 PM
Sharknose's Avatar
Sharknose
Would you be upset if they fell out?
Old Jun 23, 2011 | 03:24 PM
DoubleZ's Avatar
DoubleZ
ha good point
Old Jun 23, 2011 | 03:29 PM
Squirrel67's Avatar
Squirrel67
Just about every fastener on a HD needs at least blue locktite, the heating and the cooling of the motor and the viberation will loosen them in no time. And do yourself a favor and get the torque wrench or the money you save on not getting one will be spent on a tap and die set.
Old Jun 23, 2011 | 04:14 PM
Spanners39's Avatar
Spanners39
I been wrenching for 35 years and I only use torque wrenches on head bolts or motor parts that need a high torque setting. Itty-bitty screws and stuff don't need a torque wrench, just common sense....if you don't have any of this you should stay away from wrenching.....you can't buy it from NAPA ;-)
