map sensor removal
Old Jun 29, 2011 | 07:19 PM
BYRDNUTZ's Avatar
BYRDNUTZ
Smile map sensor removal
someone helped thereself to my manual and i dont wana mess it up,i broke it replacing intake gaskets,any help would be appreciated
thanks
Old Jun 29, 2011 | 07:56 PM
SuperFastGlide's Avatar
SuperFastGlide
i have no clue what it is
Old Jun 29, 2011 | 08:48 PM
Northern B's Avatar
Northern B
thanks
The manual says you have to remove the fuel tank to be able to remove the intake manifold then remove the two fasteners to release the throttle cable bracket. Then you push up on the map sensor and attached seal to remove it. It says to use new fasteners when re-installing and torque to 20-35 in-lbs and to also inspect the seal and replace if necessary.
I've never done it, but hope it helps.
B
Old Jun 29, 2011 | 08:56 PM
BYRDNUTZ's Avatar
BYRDNUTZ
hey thanx alot man,just what i needed to know!
tuff7582
Oct 26, 2017 02:14 PM
schmitty1226
Sep 17, 2015 10:24 AM
bbass
Electrical/Lighting/Alarm
Aug 7, 2014 09:24 AM
nevil
Sep 23, 2009 09:45 PM
waffler
Oct 17, 2007 08:47 PM
