My bike just Died
Old Jul 11, 2011 | 05:02 AM
Thogs_stilen's Avatar
Thogs_stilen
Default My bike just Died
So today heading out to work on my bike. Barely got out of the driveway And it just cuts and dies. As if I hit the kill switch. I have a 2004 Dyna low rider. It will not even turn on. When I turn the key to the on position nothing comes no lights no nothing. So turning over isn't even in the question yet. I have it on the battery tender tonight so we will see in the morning. But anyone have any other Ideas for if this does not work?
Old Jul 11, 2011 | 05:31 AM
Fridge's Avatar
Fridge
Check your battery terminals are tight.
Old Jul 11, 2011 | 05:51 AM
ImNoPrince's Avatar
ImNoPrince
And the Ground on the engine and frame , but start at the battery like PP stated.
Old Jul 11, 2011 | 06:38 AM
HOGRIDA_06's Avatar
HOGRIDA_06
I would guess a loose ground wire. Disconnect your battery and reconnect using a little blue loctite.
Old Jul 11, 2011 | 09:49 AM
bobnehoc's Avatar
bobnehoc
If none of the above works check the main fuse and or relay.....
Old Jul 11, 2011 | 10:19 AM
fxd03's Avatar
fxd03
rip !!!
Old Jul 11, 2011 | 10:35 AM
SteveO-ll's Avatar
SteveO-ll
I would check the ECM fuse. It happened to mine (out of the blue) on a run over to Atlanta last month. It looked good as it was cracked and not blown, I used a meter to find it........
Old Jul 11, 2011 | 10:47 AM
DSnoopy's Avatar
DSnoopy
Whatever you do, you better get in your car and get to work!
Jesus Zuniga
Oct 8, 2017 07:01 PM
Elijah Lynch
Aug 25, 2016 03:13 PM
sfad
May 4, 2014 10:36 AM
snapbean16
The General Motorcycle Forum
13
May 4, 2012 08:54 AM
mikerm250
Jul 5, 2010 05:06 PM
