Tach gets crazy, hesitation, eventually kills
Old Jul 20, 2011 | 11:44 PM
Nodnarb's Avatar
Nodnarb
5th Gear
Default Tach gets crazy, hesitation, eventually kills
I could use some help with diagnosing the problem.
This is a 94' EVO motor. Here's the chronologic list:
First the tach started getting wonky and wouldn't read accurate over about 2500 rpm, and over 300 rpm its bouncing top to bottom. Rode like this for about a day.
Then the motor would experience hesitation at around 2800-3000 rpm. As rpm built gradually the hesitation was WAY more noticeable. If you whacked the gas wide open you could blast thru it without much to notice.
Then the hesitation got worse and caused the bike to kill, repeatedly. If I let the bike sit for a while (30 min or so) I could restart and continue the ride. Until it killed again.
Someone mentioned that it sounded electrical? I have no clue. I'm open to suggestions.
Thanks in advance
Old Jul 21, 2011 | 07:57 AM
WG2011's Avatar
WG2011
Not sure what the deal with the tach is but if it were me I would change the spark plugs (cheap test/trial) If its hesitating and has a fiar amount of miles on it plugs could be the issue. Just one thought and a cheap and easy thing to try. Honestly could be a million things but plugs is a good place to start and possibly wires if its got ALOT of miles.
Old Jul 21, 2011 | 11:39 AM
Nodnarb's Avatar
Nodnarb
5th Gear
Thanks. I guess that's where I'll start.
Old Jul 21, 2011 | 12:41 PM
WG2011's Avatar
WG2011
One other thing to try is adding some seafoam in the tank for a few tanks maybe your carb is a bit on the dirty side as well. These are just a few things to try that are relatively cheap to do and very easy to do yourself. Good Luck hope it works for ya.
Old Jul 21, 2011 | 03:32 PM
Garyk's Avatar
Garyk
I had a similar problem one time on an FXR, turned out to be a bad battery, tach would act crazy, engine sputter..
Old Jul 23, 2011 | 10:38 AM
mtnlvr's Avatar
mtnlvr
My identical experience last year just before Sturgis.
Old Jul 23, 2011 | 11:20 AM
O-Town D's Avatar
O-Town D
"I had a similar problem one time on an FXR, turned out to be a bad battery, tach would act crazy, engine sputter.."
On my old FXR it was the hot lead coming off the ign-key switch; wire insulation had rubbed away and bare wire was shorting out against the rocker cover...
Maestro886
Jul 9, 2012 09:12 AM
Kushman
EVO
Apr 29, 2012 08:01 AM
Booey424
Sep 10, 2008 09:02 AM
Booey424
Sep 9, 2008 07:30 PM
solitaryman54
Ironhead
Apr 2, 2007 01:54 AM
