Back firing
Old Jul 28, 2011 | 05:43 AM
rorywebsite's Avatar
rorywebsite
Stage II
Default Back firing
I have a 2008 Fat Bob and have recetly had some Vance and Hines slip ons fitted. Since then, when I throttle down to change gear I get some back firing, not much but its annoying. Any one know why and how to stop it? Thanks
Old Jul 28, 2011 | 05:45 AM
SteveO-ll's Avatar
SteveO-ll
Either you have an air leak in the exhaust , or your fuel management needs to be adjusted (tweaked).
Old Jul 28, 2011 | 06:07 AM
OldMike's Avatar
OldMike
That sounds like decel poping, welcome to Hell!
Old Jul 28, 2011 | 08:57 PM
coop creek's Avatar
coop creek
"decel popping". It is from unburnt fuel getting into your pipes where it meets O2 and ignites. It can be tuned out. I had the pops on my 2007 successfully tuned out. It took a competent tuner (not available at the local dealer, I had to go elsewhere), a mastertune and dynojet time to do it and it was expensive. There are other tuning options.
Old Jul 28, 2011 | 09:05 PM
coiledup's Avatar
coiledup
try some xied's and a free flowing air filter'
Old Jul 28, 2011 | 09:08 PM
nevil's Avatar
nevil
Like SteveO said, you may have an exhaust leak, most likely at the slip joint. I've reused clamps a few times with no problems but sometimes you need new ones. I use a hi temp sealant just to make sure.
You're also probably running too lean, need to add some fuel. Getting the correct tune will cure your problem.
calboy67
Feb 20, 2025 04:59 PM
Davidb.4223
Feb 10, 2016 07:08 AM
blackflame
Jun 25, 2013 09:57 PM
ddorriety
Mar 7, 2013 03:50 PM
BKSinAZ
Aug 20, 2012 11:06 PM
