I ended up putting on the SE air cleaner with a stage 1 download. I spoke with Khrome Werks - they have tested that configuration and it is fine. Very similar flow to the SE IIs. I will keep an eye on the plug condition and if anything seems to be a problem, I'll add a SERT and dyno it. But right now, it seems to ride just fine. I only get decel popping if I am engine braking (which is normal, since the engine is running faster than the throttle body setting, and it draws extra fuel - this happens with all setups I believe).
I will say that these mufflers have completely changed the low end torque curve - far beyond the stage 1 a/c alone. Krhome Werks uses a rather unique baffle design to cancel out the high frequency sounds - but the actual flow of exhaust is straight through (you can see daylight through the mufflers) - so they have done a really good job with engine breathing and hp/torque improvements.
