Need Help With Dyna Forks
Old Jul 31, 2011 | 07:35 PM
olongapo1's Avatar
olongapo1
Default Need Help With Dyna Forks
Let me start with an introduction. My name is Bob. Retired military living in the Philippines. I'm a Softail owner and long time wrencher helping a buddy work on his newly purchased 2001 Dyna Low Rider. The original owner is deceased so prior maintenance actions and upgrades cannot be ascertained. We do have a PDF version of a service manual.
We are attempting to change the fork oil but have run in to a few anomalies.
1. The manual gives fork oil amounts in both Fluid Volume = 10.7 ounces, and length measurement (top of oil level to top of tube) = 7.2 inches. However when pouring 10.7 ounces of fluid into the fork tube, the fluid level measurement is 5.25 inches. Yes, the fork slider was cycled and the fluid has settled into all cavities. Experimenting found that a fluid level of 7.2 inches equals roughly 8.5 ounces of oil which in my opinion is to little fluid.
Question: What is the correct amount of fork oil for this bike and can anyone explain these service manual measurement anomalies we found?
2. The springs removed from the forks have progressively wound coils. I believe the springs may be "Progressive Suspension" stock height, however there was no spacer installed. I've used Progressive Suspension springs in my Softails both stock height and lowered and each required a spaces.
Questions: (A) Did Harley ever use progressive wound springs in Dyna's? (B) Does Progressive Suspension stock height springs require a spacer and if so what is the optimum spacer length? (C) What is the required fluid amount if using Progressive Suspension stock height springs?
Any info is appreciated and you can mail me direct at olongapo2@gmail.
Thanks
Bob
Old Jul 31, 2011 | 08:46 PM
08fxdf43202's Avatar
08fxdf43202
I'm sorry I don't have the specifics on an 01 Low Rider, but I was wondering if you're measuring the fluid height with or with out the springs installed?
Old Jul 31, 2011 | 09:27 PM
olongapo1's Avatar
olongapo1
Measuring properly with springs removed.
Old Aug 1, 2011 | 08:19 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Make a fork level gauge like a real suspension shop uses found here on the video LINK
Clean your forks correctly found HERE (near the bottom)
Those 39mm forks come with progressively wound springs.
mjeddy78
Nov 19, 2017 06:40 AM
zippster
Dec 6, 2016 03:31 PM
misfitJason
Aug 21, 2014 10:36 AM
Alpha Mike
Apr 20, 2014 10:35 AM
dynalo
Oct 19, 2010 11:52 AM
