Fat Bob Foot control question
Old Aug 1, 2011 | 07:05 PM
CigarDogHD's Avatar
CigarDogHD
Default Fat Bob Foot control question
I have searched through threads, but haven't been able to find a clear answer to my question, so forgive me if I've overlooked it somewhere. I have a 2011 fat bob and have found someone local with a 2006 street bob willing to trade foot controls with me. Question is, will it work? Is everything interchangeable? Thanks for your input.
Old Aug 1, 2011 | 09:05 PM
Dustdevil21's Avatar
Dustdevil21
They should, but if you have true forward controls, nothing out through your primary, then you will have to do some serious work. Your outer and inner primary will have to come off for the trade.
Old Aug 2, 2011 | 07:14 AM
CigarDogHD's Avatar
CigarDogHD
Thanks Dustdevil. I knew they're would be major work involved, but that's why I was trying to find a trade. I know just to buy the new inner and outer it was looking like 700-800 clams. Thanks again for the quick response.
Old Aug 2, 2011 | 09:32 AM
Dustdevil21
Hard thing is to find someone to do the trade with. If you have the mid's it is much easier. Just disconnect the mid shifter linkage and attach the longer linkage to the forwards. Then just rotate the "old" mid control arm back behind the inner primary case, and put a cover over the exposed shifter splines. Or you cut the old shifter out, putting a new primary cover on and plugging the rear hole.
Good luck!
ChucksterD
Jun 6, 2018 07:01 PM
amsedan43
Oct 5, 2017 07:27 PM
JackHoleRacer
Stock Harley Take Offs
Feb 18, 2014 11:19 PM
ddellostritto
Jun 12, 2012 11:48 AM
bgbdbrwn
Nov 8, 2007 07:43 AM
