Clutch question
Old Nov 14, 2006 | 12:44 AM
DougsDyna's Avatar
DougsDyna
Default RE: Clutch question
ORIGINAL: LawrenceFromTorrance
I've had this experience and it came from too much oil in the primary. If there is too much oil it gets between the clutch plates and causes a drag. Checking the level of the primary fluid is rather easy, I would do this first.
This is a good idea......... The stealers mush have plenty of extra oil. They overfilled all 3 of my bikes holes at the 1k service.
Old Nov 14, 2006 | 03:14 PM
stubby's Avatar
stubby
Hey L; I was leaning towards that. Another possibility is that dino oil supposed to be 20w50 is actually much thicker. I have a manual and spotted some valvoline 20w50 designated for wet clutch. Will drain dino and replace.
Old Nov 14, 2006 | 11:56 PM
DougsDyna's Avatar
DougsDyna
ORIGINAL: stubby
Stubby, I would lean towards 10w40........... You are probably better off putting HD's regular Primary oil in for the clutch....(not Syn3).
It is good enough stuff, and they can't give you any ****, about using the wrong fluids if there is a dispute.
DougJ
Old Nov 15, 2006 | 08:54 AM
WdGldDave's Avatar
WdGldDave
I agree with Doug. Use the HD Primary oil. It will be easier when working with the service folks. Also, the HD primary oil works well. While you are at it, see if all the fluids are at the proper level.
Old Nov 16, 2006 | 04:34 AM
WildBill76's Avatar
WildBill76
Buy a manual and Adjust the clutch youself. Engine should be cold. Also try synthetic 20w-50 in the primary, it flows better at low temps. I use Mobil 1 V-Twin. Even though it has a little moly in it, my clutch has not slipped any.
osceana
Sep 23, 2012 04:26 PM
luisan
Jun 19, 2012 12:58 AM
Chicago Bob
Feb 20, 2010 10:37 PM
sporty06
Aug 14, 2007 02:51 PM
jmbear328
Aug 23, 2006 12:52 AM
