$55 fairing...installed
Old Aug 22, 2011 | 10:27 PM
018245's Avatar
018245
Default $55 fairing...installed
Similar to the dirtbike peg thread...I like the HD clamshell and HD Vrod fairings, but just didn't feel like spending the coin on either. Upon searching Ebay I found these "fly screen" fairings for $55. It comes with a bracket which mounts to the top triple tree on a sportster. I welded up longer mounting extensions and used from 1.25" cheapo rubber coated band clamps from the local Ace hardware. I was having a shitty day and my welds are horrible. Ontop of that, the hardware store clamps LOOK cheap. So either I wrap the clamps on the bars with a bandana...lol...or I find some machined 1.25" clamps to work (any ideas regarding the clamps?). When my dad gets back into town, it's possible we could make some. At any rate, I found a cheap fairing and fairly easy way to mount it. It will do until i find something better.
EDIT...now that I think about it more...I could make a bracket which mounted using the bolts which bolt the t-bars on...would be a cleaner look
Old Aug 23, 2011 | 12:32 AM
meatpunch's Avatar
meatpunch
Nice bike man. I love the rugged look you have going there. I like the way it sits, how much did you lower the rear?
Old Aug 23, 2011 | 12:36 AM
018245's Avatar
018245
thanks...the rear is lowered 1" or so with 11" progressive 412's
Old Aug 23, 2011 | 12:43 AM
DCLXVI's Avatar
DCLXVI
I think you have the right idea. If you make a one piece bracket that gets sandwiched between the top triple clamp and the risers for the bar it should be plenty sturdy and would clean it up a bit. Is there a bottom bracket?
Old Aug 23, 2011 | 12:46 AM
018245's Avatar
018245
no bottom bracket, just three mounting points for the upper one...although it only came with one bolt...so I'll go get some tomorrow...I'm thinking of sandwiching a bracket between the underside of the top triple clamps and the bolt heads vs. ontop where its more visible
Old Aug 23, 2011 | 01:28 AM
EricInNCa's Avatar
EricInNCa
Once you get it secured and cleaned up a bit, you'll have a nice looking little fairing...
Old Aug 23, 2011 | 01:42 AM
DCLXVI's Avatar
DCLXVI
Under side will work too if you can get it to clear the headlamp.
Old Aug 23, 2011 | 01:51 AM
HemiOrange's Avatar
HemiOrange
For sturdy and inexpensive clamps check out J&P Cycles #7000125 and the other diameters that the offer, they cost around $8 ea.
Old Aug 23, 2011 | 02:00 AM
018245's Avatar
018245
awesome...thanks...if I can't figure out a way to mount it under the front triple tree tomorrow morning, I'll go that route
Old Aug 23, 2011 | 02:24 AM
caaraa's Avatar
caaraa
looks nice,i like it!
