Can someone with a Fat Bob do a quick check for me?
Old Aug 23, 2011 | 01:07 PM
Foxster's Avatar
Foxster
Default Can someone with a Fat Bob do a quick check for me?
I just swapped out the stock fork springs for some Progressive ones. Now when I sit on the bike with the front brake applied and push forward so the forks compress I hear a noise as the forks go down and then back up again, sort of a muffled clunk.
I don't know if this is just the floating calipers moving about and so the noise was there before or if this is something new.
Can someone with a Fat Bob go try it for me and tell me if they have a noise too?
Cheers.
Old Aug 23, 2011 | 02:36 PM
kcoombe's Avatar
kcoombe
I did not hear it on mine.
Old Aug 23, 2011 | 02:42 PM
08fxdf43202's Avatar
08fxdf43202
Mine doesn't.
Old Aug 23, 2011 | 02:57 PM
4trax's Avatar
4trax
Cheers.
I just checked mine and my wifes, and they both did the same thing. The way I did this was, I got on them and stood up, grabbed the front and pushed forward kinda hard to compress a decent amount and they both made that clunk noise. Ours have never been touched so.... Hope this helps ease your mind.
Old Aug 23, 2011 | 03:08 PM
ynots's Avatar
ynots
my 2010 superglide does it. I also will be installing some progressives springs
Ill be keeping an eye on this post
Old Aug 23, 2011 | 03:56 PM
Foxster's Avatar
Foxster
Thanks, guys.
Looking closer while bouncing the forks with the brake on I can see the front wheel rotating a small amount as the clunk occurs. I know this is supposed to happen cos of the floating disks. I'll put it down to that until I get a chance to ride it and hope that there is no clunk there while riding normally.
Its pissing down outside at the moment so it will have to be tomorrow. I'll post then and let you know.
Old Aug 23, 2011 | 09:27 PM
neocontra's Avatar
neocontra
It's not the floating rotor it's most likely that the steering head bearing is loose (or on the looser side) and needs to be tightened up.
Old Aug 24, 2011 | 03:31 AM
Foxster's Avatar
Foxster
Good thought but its not that. That's a different clunk that I fixed a while ago by adjusting the fall-away. Nor is it the other front-end clunk of loose tank-mount bolts, which are tight on my bike.
I've been checking around and had it confirmed that the noise I have is normal and comes from the brakes. So that's three different causes of front-end clunks on these bikes; no wonder there's confusion.
Old Aug 24, 2011 | 10:13 AM
Foxster's Avatar
Foxster
Been out for a run today. No clunks.
So, it is just the caliper moving back and forth when pushing down with the front brake on. Panic over.
Old Aug 24, 2011 | 10:43 AM
CRZYLGZZ's Avatar
CRZYLGZZ
Clarify you're request....are you askkng if the brakes make a noise, or the springs and fluid within the fork...
Assuming you mean the brakes. Mine make a noise as the caliper applies pressure to the brake pad. I naturally assume its the caliper receeding as the brake is released. Causing the pads to sorta shift in its place .
KingenCo
Jul 5, 2020 09:59 PM
steves86ta
Apr 17, 2015 11:19 AM
CitizenBT
Wheels/Tires
Jul 8, 2013 07:16 PM
mikeo33y
May 24, 2013 04:38 PM
tstyles
Jul 10, 2009 06:58 AM
