Paint clear Memphis Fats
Old Aug 24, 2011 | 10:56 AM
DGDyna's Avatar
DGDyna
Question Paint clear Memphis Fats
What kind of paint can I use? Epoxy, enamel, latex???
I installed my new Memphis Fats windshield then realized that I'd like the black better than the clear. Called the stealer to return it. He said it would be $25 restocking fee (no sweat, I thought. It's worth it).
Then he said Memphis Shades wouldn't take it back because I installed it and there would be scratches from the acorn nuts holding the bracket to the windshield.
That's interesting because the instructions tell you NOT to use the nylon washers that were on the windshield when you put the bracket on. (Note to self: use the washers next time)
Any idea's?
Old Aug 24, 2011 | 11:32 AM
JRK5892's Avatar
JRK5892
i am confused with what you are painting... the whole shield or the hardware?
Old Aug 24, 2011 | 11:46 AM
DGDyna's Avatar
DGDyna
Smile
Good question. I should have been more clear.
It's the lower portion of the windshield... below the top cross bracket. Mine is clear. I want to paint it black (no royalties paid to the Rolling Stones for the use of that statement).
Old Aug 24, 2011 | 11:54 AM
JRK5892's Avatar
JRK5892
i would scuff with red scuff pad, etching primer, gloss black accrilic and accrillic clear
Old Aug 24, 2011 | 12:26 PM
xantasm's Avatar
xantasm
Go to the auto parts store and get a cheap roll of darkest limo tint window tint you can find. That way if you don't like it you can reverse it and it was a cheap project that's not irreversible. Remove all the hardware and with a piece of tint larger than the area your working with use excessive amounts of soap and water until its situated properly on the part of the shield you want (preferably so that when the hardware goes back on it covers the edges) and then let dry. Once its dry use an extremely sharp razor blade to trim off the excess around the edge of the shield. If it doesn't work correctly repeat the above steps until your happy with it. You can choose light smoke colored, mirror tint, or completely blacked out limo tint. If your not confident enough to try it yourself ask around at the body shops to see how much one of the local tint specialists would charge for just a small shield like that.
Old Aug 24, 2011 | 01:12 PM
DGDyna's Avatar
DGDyna
Joe - That's the answer I was looking for but the tint option is something I didn't even think of.
xantasm: It sounds like a better move. Thanks for the instructions. I've seen shitty tint jobs so, since this isn't something I've ever done, it might be the time to let professional do it. Can't cost much even if I let them supply the tint.
Thanks both.
Old Aug 24, 2011 | 01:48 PM
PHA-Q's Avatar
PHA-Q
Cannot tint plexi.....My tinter said NO Way... Some kind of reaction,
Use Krylon Fusion plastic paint.
Old Aug 24, 2011 | 02:41 PM
JRK5892's Avatar
JRK5892
you can tint it... we did my bro's wing... took forever!!!!! and was a pain in the ***... all the tinters in the area said no impossible... we took that as a challenge... came out great but took both of us and some time
I have used the Krylon plastic paint on snowmobile shields with great results
that is what my sled is shot with then i airbrushed it
Old Aug 24, 2011 | 03:05 PM
PHA-Q's Avatar
PHA-Q
I tried a couple tinters in the area, they all said it would react to the plexi, I just used the Fusion on my 1/4 fairing and it turned out great, no scuffing, all i did was grease & wax remover, then a pre paint prep rag, No regrets,
The windshield on that wing looks good though, good job on that JRK...
Old Aug 24, 2011 | 03:12 PM
JRK5892's Avatar
JRK5892
was a bitch! both of us swore never again! and then... this wekend i am doing my sport bikes! hahaha
