wide glide 49mm trees?
Old Aug 25, 2011 | 10:40 AM
06redneck's Avatar
06redneck
Default wide glide 49mm trees?
has anyone put a set of 49mm wide glide trees on their street bob?
Old Aug 25, 2011 | 10:54 AM
SC-Longhair's Avatar
SC-Longhair
8 seconds on google using "wide glide conversion street bob" as the search field yielded this:
https://www.hdforums.com/forum/dyna-...treet-bob.html
Old Aug 25, 2011 | 03:03 PM
06redneck's Avatar
06redneck
thanks, due to the shortage of custom wheels for the mid-glide front end, im going to convert to wide glide and a 21". DNA told me mid glide hubs will be over a month out, i cant wait that long.
Old Aug 25, 2011 | 03:07 PM
p51bombay's Avatar
p51bombay
Don't forget that WG trees are raked - if you don't want that use Fat Bob trees, the black ones from HD are actually prices pretty good if you factor in the cost of powder coating.
Old Aug 25, 2011 | 03:10 PM
06redneck's Avatar
06redneck
so the fatbob keeps the same rake? Im going to a 21" so i think the rake will look a little better with that.
Old Aug 25, 2011 | 03:12 PM
p51bombay's Avatar
p51bombay
No experience with the 21 or raked trees but yes, the FB has the same rake as your SB - I put a set on my super glide and they look really good.
Old Aug 25, 2011 | 03:17 PM
06redneck's Avatar
06redneck
thanks
Old Aug 25, 2011 | 05:09 PM
AFMM3's Avatar
AFMM3
Don't forget that the WG forks are 2 inches longer (to go with the 2 deg rake in the trees) than your SB. I also went with Fat Bob trees but went the other way with 16 inch tires.
Old Aug 25, 2011 | 06:09 PM
WS6 Formula's Avatar
WS6 Formula
You don't need the Wide Glide forks, the original forks with the Wide Glide triple clamps and the 21" wheel will give you the same stance as what I have.
Old Aug 25, 2011 | 07:06 PM
2011Deluxe's Avatar
2011Deluxe
Correct.
