Best paint for exhaust shields?
Old Sep 6, 2011 | 09:15 AM
Guest
Guest
Posts: n/a
Default Best paint for exhaust shields?
Howdy friends,
Been reading through the forums on painting exhaust heat shields...tyring to come up with an all-in-one, best approach.
For those that know, there are a variety of paints out there good at a variety of temps...so, which paint is the best that also produces the best results? 500 degree? 1200 degree?
Thanks!
PS. I've got a 2012 DWG, and for "us" with the new 103 CI motors, it's a pain waiting for the big aftermarket companies to come up with their exhausts...I hear it's an "O2 sensor issues, mainly the bung connection"
...aint that the truth!
Old Sep 6, 2011 | 09:28 AM
kcoombe's Avatar
kcoombe
I used VHT 2000 deg and it seems to be holding up well.
Old Sep 6, 2011 | 10:03 AM
cjlandry's Avatar
cjlandry
Regarding the o2 sensor bungs, it's really not much of an issue as you can buy aftermarket pipes and have the correct bungs welded in place of the others. Any muffler shop should be able to handle the job in minutes.
Old Sep 6, 2011 | 10:21 AM
oakspeed's Avatar
oakspeed
BBQ paint works great.
satin black.
Old Sep 6, 2011 | 11:55 AM
bikerlaw's Avatar
bikerlaw
I would contact Joe at Powder Pro. He will powder coat them for you. Do it once and they will last forever and look awesome.
________________________
Old Sep 6, 2011 | 12:13 PM
superrooster2003's Avatar
superrooster2003
painted mine with the appliance epoxy and have had no problems
Old Sep 6, 2011 | 01:11 PM
Guest
Guest
Posts: n/a
Back to the question, does anyone know the right paint temp to use for this?
Old Sep 6, 2011 | 01:27 PM
spankdog's Avatar
spankdog
My dealership (Cajun Harley Davidson) makes machined adapters to fit the new O2 sensors in the pre 2012 pipes. The service manager told me they are thinking about selling them. For exhaust paint I have had really good luck with Krylon BBQ paint.
Old Sep 6, 2011 | 01:33 PM
06redneck's Avatar
06redneck
i wouldnt recommend standard powdercoat, i did mine and in certain spots it will bubble, exhaust gets really hot, like 1200 degrees in some spots. i did have them recoated using high temp powder coat and they work fine. if i could go back, id just rattle can them high temp spray paint.
Old Sep 7, 2011 | 01:34 PM
RDFXDF's Avatar
RDFXDF
Rustoleum 2000 degrees paint. They have the high temp primer as well at Advance Auto Parts.
