wiring of rear signals and brake.
Old Sep 9, 2011 | 12:28 PM
Reaper_ggy's Avatar
Reaper_ggy
Default wiring of rear signals and brake.
Hey I got a fxdwg'10 with the rear brake light on the fender and was wondering if any of you throw it away and just use theyre signals as brake lights. If so how did you organised the wiring. Thanks
Old Sep 9, 2011 | 01:06 PM
1HD1C's Avatar
1HD1C
unless youre in the US i dont think that would be legal
Old Sep 13, 2011 | 03:08 PM
Reaper_ggy's Avatar
Reaper_ggy
Thanks but ... that really doesnt count.
Old Sep 13, 2011 | 05:26 PM
Robbie13's Avatar
Robbie13
LOSER
I just unplugged my brake light (center) and tucked away under the seat. I moved my turn sigs forward. If I ever decide I need it back it's still there. Don't know if that helps you or not, but thought I would share that.
Old Sep 14, 2011 | 06:40 PM
Reaper_ggy's Avatar
Reaper_ggy
Thats exacly what I wanted to know. In case, I don't know just cutting it will end up in no sig as well
Old Sep 14, 2011 | 06:47 PM
Robbie13's Avatar
Robbie13
LOSER
I taped of my plug with electrical tape and let it rest to keep out water and dirt. Everything else still functions as should and no alarms or codes are shown on my speedo.
Old Sep 18, 2011 | 07:43 AM
Reaper_ggy's Avatar
Reaper_ggy
Sweet.
Did you use the oem rear fender ?
How did you make it hold in place without the strut ?
Old Sep 18, 2011 | 08:20 AM
Robbie13's Avatar
Robbie13
LOSER
The struts have two bolts holding the fender in place on each side. I did away with the very rear holes when I cut my struts. On the very front of the fender in front of the back wheel there is a slotted hole I used to put a bolt in and attach it the frame. That hole in the fender lined up perfect with an existing hole on the frame. I put the bolt in the frame with a nut and lock washer (all stainless) then I put the fender on with another nut and flat/lock washer. If I need to take the back fender off I only have one nut to take off in front of the back wheel.
Old Sep 18, 2011 | 08:21 AM
Robbie13's Avatar
Robbie13
LOSER
I'm still using the forward fender strut holes for the fender as well.
Old Sep 19, 2011 | 04:02 PM
Reaper_ggy's Avatar
Reaper_ggy
I'll take a look at that !
I guess you dont have picture of you're process ?
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
