Hard starting Dyna
Old Sep 22, 2011 | 10:39 PM
HemiOrange's Avatar
HemiOrange
Originally Posted by clicker01
Have a cranking amp draw test done to see if the starter is in spec. Slow cranking could indicate excessive amperage draw and if the starter isn't cranking fast enough, the bendix gear may not be thrown out fast enough to engage the ring gear all the time. The fix could be as simple as replacing the brushes and cleaning up the commutator.
That might help. Another $10 possible fix is to buy a starter mounted push button like the Thunderfire from Jireh Cycles, it circumvents a lot of wiring and will even help start the bike with a low battery. I have one, but haven't needed to use it yet.
Old Sep 23, 2011 | 06:34 AM
Keith_71's Avatar
Keith_71
the starter spins the motor over just fine and fast
tmultra
Apr 17, 2018 09:42 AM
h964
Mar 16, 2013 04:02 PM
RoguePhelon
May 3, 2012 03:03 PM
Jessie
Aug 27, 2011 04:02 PM
ScreamerII
Mar 17, 2011 01:55 AM
