Minor Crash on Bob
Old Sep 29, 2011 | 06:56 AM
dispatchokirt's Avatar
dispatchokirt
Default Minor Crash on Bob
Greetings,
I never believed the old saying there are two types of bikers, those that have been down and those that will, howver, that all changed last Monday. The reason I am posting this is so I can learn from my mistake. I was on Hwy 4 and tight, narrow, cruvy road in California. Was a awesome day, and mistake #1 - I decided to ride in a tee shirt and tennis shoes. A mistake I dont plan on repeating! I came around a real tight turn, thankfully, at a low speed apox 25-20 and found gravel all the way across the turn. The next thing I knew I was flying thru the air and the bike was on its side. Thankfully I only had road rash and brusing to my right side. The bike will need new bars and turn signals, and the tank got a nice abrasion and well as the HD insginia. My question is how could I have avoided goiong down. I think I may have hit the front brake a little hard, but not really sure.
Thanks in advance!
Old Sep 29, 2011 | 07:10 AM
Maclugie's Avatar
Maclugie
You could have avoided it if you saw the gravel in time to straighten the bike up.
Old Sep 29, 2011 | 08:26 AM
128auto's Avatar
128auto
I hit gravel riding 2up a week ago, didn't play attention, freak me out, one leg is on the ground dragging, almost dropped but saved it. I have been a few accidents 20 yrs ago but hopefully I WILL NOT lol.
Old Sep 29, 2011 | 10:34 AM
8541hog's Avatar
8541hog
Glad no major injury or damage.
Ride ahead of your bike, in other words you have to constantly look 50' ahead on the road to see what's coming at you.
If you realize you have loose ground in a turn, stay off the front brake, gravel, curves, and front brakes do not mix because you have no control if the wheel locks up on loose ground, or momentarily locks and releases it is difficult at best to control.
I recently had a similar dumping, but in the rain. My rear brake failed and I had to use the front, slick roads and front brakes do not get along very well, especially when it is an ohshit moment since you tend to grab more than you really should, human nature.
Old Sep 29, 2011 | 10:37 AM
EricInNCa's Avatar
EricInNCa
Aside from seeing the gravel ahead of time and being able to straighten the bike up (ever so slightly) while using "mostly" back brake to come to a straight line stop, you should never hit the front brake in a low speed turn. Especially when there is gravel. You could have used the rear brake and possibly slid the back end out a little but when the front end starts to slide, you're done. Another point is that you should try to do all of your braking before entering the turn in the straight line, not while actually in the turn, if anything your roll the power on while your flow through the turn. Hope to have helped a little.
Old Sep 29, 2011 | 10:39 AM
Honey-Badger's Avatar
Honey-Badger
Yes... And LAY OFF FRONT BRAKES in tight turns... lightly drag the rear brake... you can apply pressure to the front once, or if you straighten the bike up.
Old Sep 29, 2011 | 11:28 AM
DYJ's Avatar
DYJ
It's easy to talk about how to avoid gravel and tell you what you did wrong but I have been on the loosing side of gravel too... it was a lesson learned the hard way and that old saying is true for the most part.
Old Sep 29, 2011 | 11:38 AM
rtm58's Avatar
rtm58
Ditto. Get the video "Ride Like A Pro". I learned a lot from it and my wife swears by it. Glad you're ok. Had a rear ender about 2 years ago. No broken bones, but $8k damage to my FJR 1300. My Fat Bob, has not had any such experiences and I hope she never does! And stay off the front brake in dicey situations.
Old Sep 29, 2011 | 11:50 AM
overhead's Avatar
overhead
I am not an expert certainly and I would not take my advice on this because of that fact, but I do not touch either brake when I feel the bike losing traction. In my experience that only helps to lock the wheels up quicker and you lose control of the bike. If the wheels already have limited traction, hitting the brake is not going to help that situation, IMO. I come from a dirt bike background so when I feel the loss of traction I tend to do anything but hit the brake. Depending on the situation it might be rolling off the throttle or it might be hammering the throttle while steering the front tire in the direction I am sliding. Again, no expert, not claiming to be one, just my experience. Gravel in a blind turn is tough to deal with under any circumstances. Glad you came out of it OK.
Keep this in mind, if you cause your rear wheel, which already has limited traction to lock up by hitting the brake what is going to happen when it hits solid road again? The very popular high side and catapult.
Old Sep 29, 2011 | 11:56 AM
Rattle Traps's Avatar
Rattle Traps
i had a similar experience this summer..
i now take to heart the old saying...
"don't dress for the ride, dress for the crash!!"
onecoolpilot
Oct 10, 2013 11:14 PM
mountainpharm
Jul 8, 2012 09:40 PM
kelton3
Apr 2, 2008 10:15 AM
Bluerose
Nov 13, 2007 10:47 PM
