Dyna Suspension upgrade
Old Oct 15, 2011 | 10:10 PM
  #31
Austin Dave's Avatar
Austin Dave
Bought 2btls of SE fork oil at local dealer today. It sez right there on the label; Not for Street Use. Hopefully I'll be able to dodge the fork-oil cops ok.
Hate going to the dealer: way too many new bikes to ogle but I'll be true to my '03.
Anyway: SM sez to drain and then fill with 10.6oz oil. It also sez the capacity is 10.6oz. Draining from the drain-plug is gonna completely drain all 10.6oz?
Old Oct 16, 2011 | 05:10 AM
  #32
hell hound's Avatar
hell hound
the reason it says not for street use in because it is intented for track use where there are no bumps or pot holes. It will make your front end hard
Old Oct 16, 2011 | 08:19 AM
  #33
Austin Dave
fine.
Not an answer to the procedure question I asked tho. This is an experiment for me. If I do not like the results, I can change. Maybe go 50-50 with the SE and E oil.
Old Oct 16, 2011 | 09:12 AM
  #34
hell hound's Avatar
hell hound
i have done it this way in the past
with bike on lift level with front tire off the ground, take caps off applying downward force
then take a piece of coat hanger or wire and measure down untill it barely touches the fluid and make a mark, do both sides
then drain all fluid and fill it with 9 or 10 ozs. and add or subtract what is needed untill you are back at your original marks
it is more important the the levels be exactly even than being exactly 10.6 ozs.
good luck and make sure you post results
Old Oct 16, 2011 | 05:31 PM
  #35
SPECIAL ED's Avatar
SPECIAL ED
OK I skipped to the end so cut me some slack if this has already been covered. But I run Progressives stock length springs with 15 wt oil and it works really well and doesn't cost an arm and a leg either.Probably less than 90$ if you do the work yourself.
Old Oct 16, 2011 | 05:47 PM
  #36
Austin Dave
Excellent answer and tip on the coat hanger measuring. I'll do the job sometime this week. It will be some time before I get some road results.
Thank you for the help.
Old Oct 17, 2011 | 05:15 AM
  #37
stilup's Avatar
stilup
Default Nitrogen shocks
My friend has a new Switchback and they come with nitrogen shocks in the rear and drop in cartiges in the front.
Harley also learns from us and what we want.
I went on a budget at $1000.00 for all and did the work myself and I'm so glad I did. Maybe there are better options out there if you got the big bucks.
If you want black streettrackers then by all means go for it. I like my streettrackers and they have plenty of adjustment and are rebuildable.
it's all good, do what you want.
have fun I am.
Old Oct 17, 2011 | 07:17 AM
  #38
FastHarley's Avatar
FastHarley
Former Sponsor
Quit screwing around and make yourself a real oil level gauge where you can accurately fill to the exact level you need. The cartridges used are the same 20mm that HD uses but without the compression/rebound & external spring adjustments. These are not worth the money but better than what is in the stock HD suspension. Watch until you see how to make the tool if you like.
Old Oct 17, 2011 | 07:42 AM
  #39
rounder's Avatar
rounder
the measurement method is more precise and will require the removal of fork legs. you use the oz method if you keep the front end together and just drain and replace the fork oil. The amount of oil has an effect on the feel as well as the weight. more oil in the tubes makes the front firmer(too much and the travel is reduced) and less makes it softer. Through oil wt and amount, I was able to get my front end to feel and respond and feel very good on my bike. As good as the Ohlins on back, no, but it will do. It rides much better than the intiminators and 5wt. ever could. They were just too firm working with my progressive lowering kit. You can get a good riding responsive front end, but it may take some work in experimenting with fork oil amount as well as possibly blending the fork oil for a desired weight. IMO the SE oil works well with the soft stock springs and the amount(oil height) will be what you experiment with. Ultimately, I would suggest stick with stock springs and oil change and save up for a front end from Howard @ motorcycle metal. I have zero doubt that his front end will be the best you can buy. And for sure buy Ohlin shocks for the rear and Howard will set them up brilliantly for you weight and riding style.
Old Oct 17, 2011 | 10:27 AM
  #40
OkieLongHair's Avatar
OkieLongHair
Thanks everyone for all the good info!!
