Removing FXDF gauge cluster from console
Old Oct 10, 2011 | 04:25 PM
TheReprobate's Avatar
TheReprobate
Default Removing FXDF gauge cluster from console
Greetings all,
In the interest of getting the winter mod season kicked off, I'm attempting to remove the console on the Fat Bob. I've made pretty good progress, but I'm having trouble figuring out how to remove the gauge from the console.
I thought I was smarter than the speedo but I've thought wrong.
Attached are a couple of pics of what I'm working with. How do I get this thing out? Thanks in advance, fellas.
Attached Thumbnails Removing FXDF gauge cluster from console-p1010304.jpg   Removing FXDF gauge cluster from console-p1010306.jpg
Old Oct 10, 2011 | 05:02 PM
O-Town D's Avatar
O-Town D
The speedo is secured by the black plastic ring in 3 spots - if I remember correctly, carefully pry the ring away from the speedo with a small screwdriver just enough until you can lift the ring past the little nub on the back of the speedo - once you do the first one the other two are easier. Then just push speedo from underside out through the top of the dash. Here's a close-up from my "Speedo/Tach Install" album:
https://www.hdforums.com/forum/membe...-of-speedo.jpg
Hope that helps.
Old Oct 10, 2011 | 05:29 PM
TheReprobate
Default Thanks!
Just what I was looking for, Sir. Thank you very much!
Very Respectfully,
Laurence
Cobrajett
Electrical/Lighting/Alarm
13
Jul 3, 2021 03:48 AM
JamesDyna33
Jul 15, 2016 12:12 PM
Scorpio49
Dec 9, 2013 09:22 PM
rockymtnhigh
Jul 14, 2011 09:54 PM
