Is there a bad year for a twin cam engine
Old Oct 11, 2011 | 01:25 AM
oldguyalso's Avatar
oldguyalso
Default Is there a bad year for a twin cam engine
I have an 09 FXDC.I am thinking about buying a used Streetglide. I thought I read that the 06 had some problems that Harley fixed later any input?
Old Oct 11, 2011 | 02:12 AM
128auto's Avatar
128auto
All TC88 have cam chain tensioners and inner bearings problem, the tensioner springs are too strong, putting a lot of pressure on the chain guides, they wear out so fast that you wouldn't believe. The only fix is hydraulic tension cam plate upgrade, that will save you a lot of trouble, the torrington b-148 bearings replaced the stock ones. Nothing bad about a TC88, they are as good as 96 if you have a new auto chain tensioner system installed. I used to have a 06 Fatboy, don't ask me how I know.
Old Oct 11, 2011 | 07:40 AM
Good_Apollo's Avatar
Good_Apollo
Not the only fix, if your crank runout is in spec you can go gear drive. The crankshafts on the 99-02 were more sturdy than the later bikes so more likely to check out for gear drive. I'm doing a 97ci build this winter, going gear drive if all checks out, otherwise I will do the SE hydraulic kit
Old Oct 11, 2011 | 08:57 AM
128auto's Avatar
128auto
Yeah that too, gear drive is good but I can't stand for the whining sound lol. Don't forget the new cam plate unit has a better oil pump, you basically upgrade the lubrication system at the same time. And yes the crank material is better prior to 02 model, I don't understand why HD wants to cut cost and build a cheaper crankshaft, it doesn't make sense to me.
Old Oct 11, 2011 | 09:44 AM
Austin Dave's Avatar
Austin Dave
Hmm...did not know of this concern for my '03-88. Symptoms to watch for? Mileage range? Is the SE kit the only/best option as far as manufacturer?
Old Oct 11, 2011 | 09:50 AM
128auto's Avatar
128auto
Mileage vary, some went at 30000miles or earlier. Andrews make a cam plate as well do a search.
Old Oct 11, 2011 | 09:52 AM
Energy-Dude's Avatar
Energy-Dude
Some of the 06 Dynas had stator problems and inner primary alignment issues, have not heard of any on the Touring bikes.
Old Oct 11, 2011 | 10:32 AM
parts eeter's Avatar
parts eeter
I still need a big bore kit. I like the gear drive whine. I used to run Pete Jackson "Noisy" timing gears in my small block Chevys. I think the tolerances on those years you mentioned were better, and the cranks were forged rather than cast units as well.
Old Oct 11, 2011 | 01:47 PM
nvsteve's Avatar
nvsteve
The early 06's had injector issues. See if you can determine if the injectors are the updated 25 degree.
Old Oct 11, 2011 | 04:35 PM
jamman's Avatar
jamman
it being a 06 STREET GLIDE and a touring configuration, a 5 speed, they only things i know they had were cam chain tensioners, the 8* injectors, and adding the auto adjusting primary chain would be a plus..
