Painted lowers on the Dyna
Old Oct 16, 2011 | 11:02 AM
dogma20008's Avatar
dogma20008
Default Painted lowers on the Dyna
Took a hour to sand each one, then 30mins to paint, let it sit for 3 days before putting the wheel back on. Did it all outside, just put a box under the forks to catch the overspray.
Attached Thumbnails Painted lowers on the Dyna-img-20110914-00123-1-.jpg   Painted lowers on the Dyna-img-20110914-00124-1-.jpg   Painted lowers on the Dyna-img-20110916-00128-1-.jpg
Old Oct 16, 2011 | 12:09 PM
JaronB's Avatar
JaronB
Looks good! Probably the best cheapest mod we can do!! I just used the appliance epoxy on my battery band and it turned out just as great.
Old Oct 16, 2011 | 12:19 PM
dogma20008's Avatar
dogma20008
Thanks to you, it was from your thread that I decided to do it. Im actually thinking about painting my tins with the same paint
Old Oct 16, 2011 | 02:00 PM
PigInaBlanket's Avatar
PigInaBlanket
Looks great!
Old Oct 16, 2011 | 02:21 PM
JaronB's Avatar
JaronB
Glad I can help. Tins would probably be a little sketchy unless you're good with wet sanding. I think on that big of area it will show to much orange peel. Although I've never used on anything bigger then our lowers.
Old Oct 16, 2011 | 03:14 PM
h2o's Avatar
h2o
Great job, looks just like mine.
Old Oct 17, 2011 | 12:29 PM
srurebel55's Avatar
srurebel55
dogma, looks real good. looking to do this when i get back.
question... ive never taken a wheel off, was it hard to figure out or you done it before and its easy for you? im not to mech and not many tools. i can pm you too, dont wanna steal your thread thunder. thanks tho in advance.
Old Oct 17, 2011 | 01:59 PM
dogma20008's Avatar
dogma20008
Removing the front tire and brakes were easy as pie, as long as you have the right tools, and everything goes back to gether just as easy. You can even goto youtube and find a video that gives you the basics on removal. But definetly remember, DON'T touch the front brake lever after you remove the front brake caliper off the rotor. Good luck
Old Oct 17, 2011 | 02:01 PM
dogma20008's Avatar
dogma20008
Oh and stay safe over there and Thank You
houstonhdguy
May 28, 2014 09:20 PM
h2o
Oct 15, 2011 05:55 PM
stev0n
Jun 17, 2011 10:46 PM
ksdrknite
Powdercoat & Paint
Jan 20, 2011 02:35 AM
PG13125
Feb 16, 2010 08:02 PM
