02 Super Glide electrical probs
Old Oct 22, 2011 | 09:58 PM
grunta's Avatar
grunta
Stage III
Default 02 Super Glide electrical probs
I am at a loss so thought I would try this site. My 2002 S/Glide has LOST the power to the following; engine light, instrument lights, fuel gauge, hi/low beam and all indicators. The following HAS power: horn, frt parker light, rr tail light, brake light and I have speedo and trip meter. I have checked the fuses all are good, checked and replaced the 30amp circut breaker. Is there any main engine fuse I may have missed, as this is driving me mad. I can not start the bike at all. I am wondering if the key is playing up but can not see how to open it to clean the terminals. Any suggestions would be helpful thanks.
Grunta
Old Oct 22, 2011 | 11:29 PM
Barz's Avatar
Barz
Check all your wiring for any pinches or shorts. I had that happen on my 02 not too long ago after my accident. It's a pain in the *** but just check it out. Especially if you have hit any pot holes or anything of that nature.
Old Oct 23, 2011 | 12:41 AM
HemiOrange's Avatar
HemiOrange
Do you have a fob? I've had crazy things happen with a bad battery in the fob.
Old Oct 23, 2011 | 07:36 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I would check the ground cables at the lug/connections end to the ground posts under the seat and behind the coil and to the starter. Sometimes the wires in the cables will corrode inside the insulation and not provide a good ground.
Old Oct 31, 2011 | 02:44 AM
grunta's Avatar
grunta
Stage III
Thanks to all, I have traced the problem to of all things, the dam ignition switch. Its amazing how a 3 way toggle switch can get you rolling again.
Old Oct 31, 2011 | 01:35 PM
Garyk's Avatar
Garyk
Glad you found it.......
nodhtims
Jun 15, 2023 07:52 PM
7!sprint
EVO
Mar 26, 2021 08:17 PM
Big Ed Beckley
Jun 8, 2017 10:24 PM
Jerseyrider
May 14, 2009 10:15 PM
pprice832
May 4, 2008 10:11 PM
