Dyna Vibration Problem
Old Dec 15, 2015 | 03:32 PM
  #71
nick@nite's Avatar
nick@nite
Originally Posted by Warp Factor
Worst on decel? That definitely points to lack of clearance at the top of the motor mount, as described in Tin Cup's post. On decel, the front of the engine is pushed down.
When I clearanced mine as in the service bulletin, my problem totally went away.
did you do it yourself? or dealer
Old Dec 15, 2015 | 03:39 PM
  #72
nick@nite's Avatar
nick@nite
Originally Posted by hell hound
i have a vibratecnics / predator mount used for sale if someone wants it
will make a good deal
PM sent
Old Dec 15, 2015 | 04:17 PM
  #73
mirrmu's Avatar
mirrmu
i just shaved my mount the other day, havent ridden yet
put jack under bike to support engine then its very easy process, you need a real small torque wrench if you want to torque to spec
ended up taking off that raised section of mount, and have about 1.3mm clearance now
also put 1 washer to shim
Old Dec 15, 2015 | 08:38 PM
  #74
ZROADSTER's Avatar
ZROADSTER
PREDATOR VIBA-TECNICS front motor mount appears to remove 75% of the vibration and stabilizes the bike when tank slappers would normally appear !
Old Dec 15, 2015 | 10:29 PM
  #75
dtwowhtwow's Avatar
dtwowhtwow
2nd Gear
Hell Hound, Do you still have the vibratecnics / predator mount?
Old Dec 16, 2015 | 06:44 AM
  #76
hell hound's Avatar
hell hound
i still have it
pm me if interested
Old Dec 16, 2015 | 01:00 PM
  #77
dtwowhtwow's Avatar
dtwowhtwow
2nd Gear
Thanks.
Old Dec 16, 2015 | 05:11 PM
  #78
MRFREEZE57's Avatar
MRFREEZE57
i still have it
pm me if interested
just curious, why did you remove your Vibratechnics?
Have been thinking on installing one when my front one fails, but also like to hear feedback by someone that has tried one.
Old Dec 16, 2015 | 08:37 PM
  #79
Super08's Avatar
Super08
There are a couple threads on here on them. The vast majority including myself are very happy with the mount. Actually I was overjoyed with mine as it cured all my problems with both vibration and wobble. The bike feels much more planted, like it is on rails. There was only one or two that I seen that had problems with them on their bikes.
Old Dec 17, 2015 | 07:49 AM
  #80
hell hound's Avatar
hell hound
I installed this mount on my 06 because i was having wierd vibration issues. The bike had fairly large cams and a drive train that i beat the hell out of for 85,000 miles. So i took off my true track mount and installed this vibraticnics mount and it did help with vibration alot. When i sold that bike i took the vibraticnics mount off because it was so dam exoensive.
my new bike 14 lowrider seems to be smooth just like it is. So now i have a smooth running bike with a true track on the self and a vibraticnics on the self. I wanted to increses the stabillity on the new bike so i installed the vibraticnincs mount on the new bike. On this bike it only seemed to help a little and only added to stabillty a little. I know for a fact that the true track increases stability in a major way, but does nothing for vibration, maybe increases it a bit if anything. So on this bike , since it was already smooth anyway, i thought i would just install the true track instead.
At certain rpms the vibraticnics mount was glass smooth and at other rpms it is similar to stock
