Dyna Vibration Problem
Old Jun 7, 2021 | 06:26 AM
  #91
HDkazHD's Avatar
HDkazHD
Default No changes to current motor mounts?
Originally Posted by John CC
Since the front mount is on an angle, as it collapses it pushes the engine towards the back. shimming the front mount just compensates for the fact that the whole thing needs to come back forward. Replacing both mounts is the only way to correct it. Consider an improved, aftermarket front mount. I'm using the Predator myself, but there are others.
Just to check if the current stock mount still requires shimming/shaving? Currently my existing mount has been shimmed/shaved, so far so good.
Old Jun 8, 2021 | 09:42 PM
  #92
John CC's Avatar
John CC
You shave it because it has collapsed. You shim it because it has pushed the engine back and the rear mount is collapsing. Any way you look at it it's lipstick on a bulldog.
Max Headflow
Sep 4, 2016 11:37 PM
dmercy
General Topics/Tech Tips
Sep 19, 2010 08:22 AM
Grayzone
Oct 16, 2008 07:40 PM
screamn1
Screamin Eagle CVO Models
Aug 1, 2008 02:23 PM
kpmurphy
Nov 5, 2006 11:22 AM
