Derby cover replacement question
Old Oct 25, 2011 | 01:47 PM
Plaidfinger's Avatar
Plaidfinger
Default Derby cover replacement question
Stupid question, but I came from a Ducati with dry clutch. Do I need to drain oil prior to replacing the derby cover or does it sit low enough to pull the cover and replace?
Old Oct 25, 2011 | 02:08 PM
shimmon's Avatar
shimmon
If the bike is upright, you can replace without loss of fluid... We are talking 06+ dyna right?
Old Oct 25, 2011 | 07:17 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
If the bike is verticle, NOT on the jiffy stand, you shouldn't have any issues other than super tight fasteners. I'd have a second set of fasteners on hand.
Old Oct 25, 2011 | 07:22 PM
bobnehoc's Avatar
bobnehoc
Put a 2x4 under the jiffy stand to keep the bike as vertical as possible and you should not have any problems....Just remember to change the gasket....
Old Oct 25, 2011 | 07:27 PM
art0565's Avatar
art0565
Everybody already said it - keep your bike upright
Old Oct 25, 2011 | 08:19 PM
DCLXVI's Avatar
DCLXVI
Just a reminder, use a T27 driver ant not a T25. The T25 seems to fit but will surely strip the fastener.
Old Oct 25, 2011 | 08:48 PM
PigInaBlanket's Avatar
PigInaBlanket
I don't stand mine upright and I can take my derby cover off without spilling anything while it's on the jiffy stand.
Old Oct 26, 2011 | 05:32 AM
cam-921's Avatar
cam-921
Well seeing as how you fill it after a change on the jiffy stand with the cover off, one would ASSume you could pull the cover on the stand without fluid loss.
Old Oct 26, 2011 | 05:49 AM
srurebel55's Avatar
srurebel55
agree with last two, dont have prob changing while on jiffy...
Old Oct 26, 2011 | 06:23 AM
YeOldeStonecat's Avatar
YeOldeStonecat
The ultimate answer depends on...."how did you top it off before?"
If you topped it off while vertical..and you try to change the derby cover while she's leaning on the jiffy...obviously it will spill a little bit. Hey..some people top it off this way as a preference..they like a little more fluid in there.
If you topped it off while on the jiffy...or just shy of topping off...she most likely will not spill when you pull the cover.
I re-use the derby gasket quite a few times...if you're even marginally careful while removing the screws..and putting them back on..she won't rip, and..I'm on 6th or 7th re-use by now, no leaks. Not a lot of pressure in there...and they are quite thick.
sprnt96
Apr 20, 2011 10:43 PM
casadelray
May 8, 2010 11:39 AM
sanlyn
Mar 19, 2010 08:15 PM
YellowHawk
Dec 28, 2007 01:33 PM
jeffbcn
May 12, 2007 05:31 PM
