Tool Bag for Street Bob
Old Nov 28, 2006 | 06:28 PM
sjcope13's Avatar
sjcope13
Default Tool Bag for Street Bob
Any suggestions for a tool bag for a street bob. Fork mounted or lower frame? Read somewhere the straps mess up the chrome if you mount the bag on the forks. Any pics would be appreciated.
Old Nov 28, 2006 | 06:46 PM
hd_sob's Avatar
hd_sob
Default RE: Tool Bag for Street Bob
ORIGINAL: sjcope13
YES, it can. The trees are aluminum, not chrome, much softer. I had a bag on mine for a short while and it gouged the $hit out of it.
If I ever put another on, it will most likely go in the lower frame/downtube area.
Old Nov 28, 2006 | 07:30 PM
TOMMAY's Avatar
TOMMAY
Mounted mine on the lower down tubes. Lined the inside with some metal flashing cut to fit so it would hold shape and used black wire ties over the leather straps to reinforce them.
Good Luck
Tom
Old Nov 28, 2006 | 09:29 PM
jimw411's Avatar
jimw411
Since i have a Cali bike, i had to remove the fuel evap canister before i could mount my bag to the bottom on the frame. I use a tie wrap on each side to secure it.
Old Nov 29, 2006 | 01:22 AM
Helix's Avatar
Helix
$13 off ebay attached with Velcro straps for the No scratch! Also if you do decide to mount a bag on your forks dont pull a dumbass move like me. My 1st tool bag was larger than the one you see and it rubbed my front fender a tad and gave me a 50 cent piece sized dull mark. I forgot to put a small bit of laminate on my fender for Chaffe protection.
[IMG]local://upfiles/17677/D9FA9C0203174D619015037C7A793F57.jpg[/IMG]
[IMG]local://upfiles/17677/654F8CCB584246DBBF23C930BFED479F.jpg[/IMG]
Old Nov 29, 2006 | 02:20 AM
Gamma742's Avatar
Gamma742
ORIGINAL: jimw411
@jimw411
What is entailed with removing that ugly fuel evap canister from my Low Rider?
Old Nov 29, 2006 | 03:46 AM
waterman7474's Avatar
waterman7474
mines attached to the bars, kind of caddywhompus around the bar and back up under the risers, it keeps it off the headlight. when i got the bike it was down at the voltage regulator but i wanted it up top where i can get into it, i keep stuff in there and like to get into it often (chapstick, few small tools, nite-time optical enhancers, camera sometimes, gum, ****, etc)
it also had the added benifit of cutting some of the wind. i am actually looking for a slightly bigger one.
Old Nov 29, 2006 | 08:54 AM
SDMF's Avatar
SDMF
I went with 4" risers and mounted it above the headlight.
[IMG]local://upfiles/9114/54640DE60E3E49AEB7E4751CC266CA84.jpg[/IMG]
Old Nov 29, 2006 | 09:29 AM
Mascman's Avatar
Mascman
I made mine a rigid mount.
It is bolted uner the triple tree, but looks like it's mounted to the forks.
My brother and I both did this and it is working well.
Rigid mount write-up.
Old Nov 29, 2006 | 10:24 AM
Bassman's Avatar
Bassman
ORIGINAL: hd_sob
ORIGINAL: sjcope13
Been there & done that - and have the scratches to prove it [:@]
Luckly I was able to buff most of them out. Now it resides on the lower downtube - atleast until I add the oil cooler.
