Before 08 top tree excepted riser,or t bars. 08 and later has integrated risers. I found a 07 top tree and put it on. Didn't need to get the mx bars that bolted to integrated riser.
Yeah, those are the ones. They said they are working on a fix for the problem. When I called, he knew exactly what I was talking about. Why they would send them out knowing it wouldnt work is not the best idea.
Kinda sounds like they need to drop a pair of bolts in then weld the bars on. I understand what you mean now. The rear bolts dont have enough room to be installed because the bolt head hits the handlebar. Maybe if they elongated the rear holes as well.
At least they made a T Bar for the guys that have the integrated top trees.
I think he said they are going to reduce the angle forward and use a slightly shorter bolt.
